Fouled air box. - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 05-30-2016, 05:04 PM Thread Starter
06vitory's Avatar
Default Fouled air box.
IMG_0916.JPG this is what I have been finding in my air box. Last week I cleaned it out it was about half full. This pic is only a thousand miles. It seem to be water somehow mixing with crankcase vapors. I changed the oil. No water I the oil. Oil looked good. Any ideas what could be causing this?
06vitory is offline
post #2 of 6 (permalink) Old 05-30-2016, 05:29 PM
no photo. click on paper clip above to download photo.
Tell us what year and model bike is a must.
if its water then you don't have it sealed good. look it over.
Your oil blow by hose you can route down to ground if you so choose to
post #3 of 6 (permalink) Old 05-30-2016, 08:35 PM Thread Starter
06vitory's Avatar
2006 kingpin with 135,000 miles
06vitory is offline
post #4 of 6 (permalink) Old 05-30-2016, 09:08 PM
Motorbikerx's Avatar
YUK!
Yeah get that blowby hose off your airbox, Had a Yam 650 one that had lots of blowby I routed a hose to make a chain oiler.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 6 (permalink) Old 05-31-2016, 11:06 AM
Love the mileage YUP thats water mixed oil
post #6 of 6 (permalink) Old 06-01-2016, 08:49 PM
While it does look bad, I would bet that you are getting condensation in your engine, and it is boiling off into the crankcase vapor line, as intended. Clovis looks to be in a fairly dry area, but in that same desert you can get a bit of water into a frying pan set out overnight (at least sometimes.) Is your bike parked in a closed garage? Is there often dew on the metal in the morning?
It would not take but a CC or two of water to make the oil vapor look that way.
I would not worry about it too much.
Also don't the CA bikes have some sort of additional clean air systems on them? Maybe an EGR? Certainly a vapor canister???
2004 Kingpin Chapin, SC
DanG144 is offline
