Scraping noise when riding 2 up - Victory Forums - Victory Motorcycle Forum
 6Likes
  • 1 Post By Shark88
  • 2 Post By half_crazy
  • 3 Post By half_crazy
post #1 of 6 (permalink) Old 06-05-2017, 09:19 PM Thread Starter
Shark88's Avatar
Default Scraping noise when riding 2 up
So I noticed this when riding with the wife, every now and again I hear a scraping noise when going over bumps, sort of like metal rubbing. Looked all around and can't figure where its coming from. Kinda hard to see without any weight on the bike and parked. Is there any adjustment on the suspension for when there more load on the bike. I don't hear it at all when riding alone.
Tourider likes this.
2007 Kingpin Tour
Bought Jan 2017 10,800 miles
Shark88 is offline
post #2 of 6 (permalink) Old 06-06-2017, 03:31 AM
half_crazy's Avatar
Final drive belt rubbing the top bolt boss on the front pulley cover. Only happens when the suspension bottoms out.
visionjohnny and SkInM4N like this.
2006 Victory Kingpin
half_crazy is online now
post #3 of 6 (permalink) Old 06-06-2017, 03:44 AM
half_crazy's Avatar
Yes, You can stiffen up the rear shock, that will help, but it's a pain in the ass to change back and forth for alone and 2-up riding.
If you get an underdrive pulley it won't rub any more. Just one more plus for the UD Pulley...
Underdrive Pully for 06 up Narrow Tire Bikes
https://www.victoryforums.com/36-vict...-thoughts.html
post #4 of 6 (permalink) Old 06-06-2017, 11:11 AM
kaitiff's Avatar
I believe i did see where someone remove that cover and ground off the boss on those bolts to good effect too.. not that I've done it. I have the same issue sometimes when riding 2-up on my KP. If I have a passenger it's almost like I'm 3 up really.. as fat as my ass is.
kaitiff is offline
post #5 of 6 (permalink) Old 06-06-2017, 11:54 AM
Yup check shock setting. With flash light look under rear fender for rubbing. While your looking look at the wires to see if they been rubbed by tire.
Here you can read about shock setting just fill in blanks.
Owners Manuals | Victory Motorcycles
post #6 of 6 (permalink) Old 06-06-2017, 08:28 PM Thread Starter
Shark88's Avatar
Thanks for the advise guys. The Under Drive Pulley looks interesting. I'm in the process of selling 2 of my other bikes right now to pay this off then I'll look into that.
2007 Kingpin Tour
Shark88 is offline
