Fuel pump - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 06-03-2018, 08:04 PM Thread Starter
Default Fuel pump
Hey guys trying to fix a 2008 kingpin that runs rough and sometimes stalls, I sprayed some carb cleaner around the vacuum lines and intake boot and it revs up so I ordered a new intake boot and vacuum lines. Today I pulled the tank and when I set it down I noticed it kept dripping from the fuel pump outlet. Is that a tell tell sign that the pump is bad? I know when I pull my 05 tank it doesn’t drip or leak but the 08 tank just keeps dripping. I thought I had read that it shouldn’t drip and if it does your pump is bad. Thanks for the help
MaineKingpin is offline
post #2 of 3 (permalink) Old 06-06-2018, 07:37 AM
Personally, if it were my bike and it's pumping out the 50 lbs of pressure it's supposed to, i'd think it's ok. I don't think there a check ball or valve preventing the pump from dripping.
Closed minded people suck.
13 Vic CC
05 HD EG
08 HD RG
John R. is offline
post #3 of 3 (permalink) Old 06-06-2018, 02:05 PM
don't forget to replace all the vacuum caps. Auto store has them
