Front end "Knock" sound 2007 Kingpin? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-12-2013, 02:16 PM Thread Starter
Question Front end "Knock" sound 2007 Kingpin?
I recently noticed that if I ride over a lot of small bumps at very low speed with the clutch pulled in or in Neutral I hear a loud knocking sound in the front end.
On pavement I never notice this. I only notice this when riding over grass at 5-10mph to get my bike from the shed to the street. I'm sure I'd hear it on the street if I rode over a lot of small bumps in rapid succession (like rumble strips).
Anyone ever experienced this? I'm worried about steering head bearings but my bike only has 22,000 miles and has been kept in a garage or shed it's entire life.
Anything else I should inspect? Loose brake caliper or pads? Nothing there feels odd when braking.
KINGCL is offline
post #2 of 6 (permalink) Old 04-12-2013, 02:25 PM
lunaticrider's Avatar
Tighten your head bearings approx 1/8th turn, more than likely the bearings have broken in and giving you the noise you've described....
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #3 of 6 (permalink) Old 04-12-2013, 02:39 PM Thread Starter
Is tightening them as simple as turning the upper steering head nut clockwise? I'm sure there is a torque setting required. I do not have a service manual.
KINGCL is offline
post #4 of 6 (permalink) Old 04-12-2013, 02:58 PM
You will not be able to torque them, you will need a spanner wrench (or you can tap it with a long punch and a hammer). Before you do anything loosen the upper triple center nut then tighten the head nut with the spanner (or punch), there is a torque value for the center triple nut not sure how much off the top of my head what the value is. You should actually remove the upper triple but you should be ok by not doing so.
DO NOT OVER TIGHTEN THE HEAD NUT, 1/8TH TURN AT A TIME!!!
post #5 of 6 (permalink) Old 04-12-2013, 03:24 PM
half_crazy's Avatar
Wiggle the front brake rotor fore and aft... the floating rotors sometime float a bit too much.
2006 Victory Kingpin
half_crazy is offline
post #6 of 6 (permalink) Old 04-12-2013, 03:34 PM Thread Starter
Thanks for the suggestions. I will take a look at it this weekend and report back!
KINGCL is offline
