Oil Plug Issue - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-13-2013, 05:46 PM Thread Starter
Default Oil Plug Issue
I have a 2011 Kingpin. Doing this oil change myself. When i took out oil plug, i did not see any washer or o ring. The Vic oil change kit has a couple of washers and one o ring. The large washer and o ring will not fit. The small washer sort of fits.
My question is, should there be a washer at all on the oil plug ?????
2011 Kingpin/X-Bow Pipes/RPW Baffles/Lloyd's Torque Tubes/Lloyd's VM1 Cams/AIV/Adj Timing gear/PC-V fuel controller
Kuryakan Grips/Mustang Seats with dual backrests
Vic Luggage rack/Vic semi hard bags with Edge Bracket
Vic Highway Bars/Piaa driving lights
Vic Lower Deflectors/Kuryakan Highway Pegs
Dyno 99HP/120T
Farmerplp is offline
post #2 of 6 (permalink) Old 04-13-2013, 06:31 PM
06vitory's Avatar
Use the smaller crush washer. If you look at the base of the plug there is a small bevel that will center the washer. Only toque to 15lbs this can be stripped if over tightened.
2006 Kingpin Deluxe
Stage 1 pipes
Dunlop D407 & D408 tires
06vitory is offline
post #3 of 6 (permalink) Old 04-13-2013, 09:40 PM Thread Starter
Thanks 06 for the info.
Dyno 99HP/120T
post #4 of 6 (permalink) Old 06-20-2013, 04:06 PM
What is the other o ring and washer for?
RustyStolzz is offline
post #5 of 6 (permalink) Old 06-20-2013, 04:57 PM
NOEMTZ's Avatar
Other models
www.noemtz.com
NOEMTZ is offline
post #6 of 6 (permalink) Old 06-20-2013, 05:37 PM
washer is stuck to bolt or motor if there was one.
Careful on how tight you get it. It only holds oil in so don't reaf on it
