Which brake pads? - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 05-02-2013, 12:38 PM Thread Starter
Default Which brake pads?
I want to replace my brake pads on a 2008 Kingpin Tour. Which pads are the "recommended" pad? And are the front and rears the same pads?
I was thinking about getting these:
EBC Double-H Sintered Brake Pads FA196HH
2013 Victory Vision in black
2008 Victory Kingpin Tour - traded
2000 Yamaha VStar 650 - traded
Cruising the coulees in God's Country (Western WI)
ljurgens is offline
post #2 of 9 (permalink) Old 05-02-2013, 12:55 PM
so-crates's Avatar
The EBC Double H pads are awesome. Only problem you might run into is that they tend to be a little harder on the rotors than the stock pads are, so they might wear out the rotors sooner...
2003 Vegas - straight pipes, Big Sucker air filter kit, black powder coated everything - foot controls, handlebars, clutch and brake housing, fork lowers, luggage rack, wheels, digital speedo with powder coated housing. Relocated key switch, red plug wires. Mustang solo seat. LED ring blinkers in front. Black DEI pipe wrap.
so-crates is offline
post #3 of 9 (permalink) Old 05-02-2013, 12:56 PM Thread Starter
Looks like these are the pads:
Front: FA347HH
Rear: FA196HH
ljurgens is offline
post #4 of 9 (permalink) Old 05-02-2013, 09:15 PM
I'm using EBC HH with no disc marring problem. Dramatically better than the OEM pads.
post #5 of 9 (permalink) Old 05-02-2013, 09:47 PM
MNBill's Avatar
My son's Vegas has had two sets of Victory pads on it and the brakes squeel like crazy. Any problems the the EBC pads like this ?? We are looking for a solution to the problem. My Local Dealer helped us with the replacement price on the first set after Vic would not cover the issue.
2011 Victory Cross Country
IPOD wiring, Cee Bailey lowers, Klock Works windshield, Corbin seat
Previous rides:
2003 Valkyrie Standard
2004 1300 VTX
1997 Honda ACE 1100
MNBill is offline
post #6 of 9 (permalink) Old 05-02-2013, 10:32 PM
Brake squeal is the result of a vibration or resonance set up between the metal back of the pad and the piston. My XR's OEM pads had a thin metal backer on them. I think some discard that with the old pads. They need to be transferred to the new ones as they are there for noise elimination.
Sand the surfaces of new pads before inserting. Place the sandpaper on a flat surface and rub the pad on it.
If squealing persists, there are products you can brush on to the back of the pad to reduce the resonance. Brake Quiet is one of those.
post #7 of 9 (permalink) Old 05-02-2013, 11:08 PM
Noemtz has some good pads. I highly recommend him.
If your budget is extremely tight you could try these...
http://www.sixity.com/motorcycle-par..._year_range=46
I installed a set on my other KP and they did just fine.
post #8 of 9 (permalink) Old 05-03-2013, 08:14 AM Thread Starter
Hi BBob, thats a great deal on those pads. Less than 1/2 of what the EBC pads go for. If they are better than the OEM pads then those would be a good choice too.
Have you ever compared these to the EBC pads?
ljurgens is offline
post #9 of 9 (permalink) Old 05-03-2013, 11:45 AM
Can't speak to longevity because I sold that KP but they worked well; about as well as the EBC I'd say.
