belt lasts how long? - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 09-16-2013, 06:10 PM Thread Starter
Default belt lasts how long?
Again im new to my 2008 kp,,,but i love it..no issues...i have about 12k on it now and was wondering when i should change the belt? how much mileage should i expect to get on it?
thanks
mark
rideforever is offline
post #2 of 16 (permalink) Old 09-16-2013, 06:26 PM
What do the man-yul say?
post #3 of 16 (permalink) Old 09-16-2013, 08:40 PM Thread Starter
not sure used bike,,didn't come with man-yul ....but just seeing what veteran victory owners have gotten on their belts....
post #4 of 16 (permalink) Old 09-16-2013, 08:47 PM
CrossRoads's Avatar
I think man-yul says to inspect and replace at 30k. There have been a few folks who took their belts to the 100k mark. If you see damaged teeth, it's time to replace. Otherwise, keep riding.
CrossRoads is offline
post #5 of 16 (permalink) Old 09-16-2013, 09:53 PM
Goatlocker95's Avatar
Here's the manual for a 2008 Victory Kingpin.
http://cdn.polarisindustries.com/pol...9921239r02.pdf
Like CrossRoads said, page 83 states to replace at 30K miles. But I also agree with him that most belts will go 50 to 75K if not more. Do a good inspection and replace once you start to see damage on the teeth.
BTW, here is the link from Ma Vic's homepage if you want to download other owner's man-yuls.
http://www.victorymotorcycles.com/en...rs-manual.aspx
2014 Indian Chieftain
Goatlocker95 is offline
post #6 of 16 (permalink) Old 09-17-2013, 12:05 AM
Bad V V's Avatar
I have an 03 Vegas with 30k miles on it and mine still looks new.
2003 Victory vegas
Bad V V is offline
post #7 of 16 (permalink) Old 09-17-2013, 06:38 AM
Pop
One of the few places I don't agree with the manufacturers recommendations. 30k is a major maintenance milestone but I'm satisfied that a full inspection of the belt and pulleys is sufficient. Replacement solely because of mileage? Seems a little harsh if everything passes muster.
I do keep a spare though. More likely to wreck one than wear one out. Victory dealers tend to not stock them if the horror stories are true so if you chew one up and don't have a replacement, enjoy the walk.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #8 of 16 (permalink) Old 09-17-2013, 08:39 AM
Term's Avatar
Well mine broke at 32K. When I bought the bike it had 28K, I had not really done much with it yet at that point. Mine broke cleanly and when I inspected it after the break, other than the place where it no longer connected to the other end it looked great. So I am not sure an inspection would have warned me. Thinking back on it a couple of times before it broke I think I heard it squeal. So It may have not been adjusted properly.
As Pop mentioned unless you live in a big city where they have a big Victory dealer, you will be looking at a week or so before getting a belt. So the question becomes do you want to change it when your ready or when it decides to break. So having a spare around is probably a good idea if you are on the upper side of the mileage limit.
2013 Vision Sunset Red - Stage 1 exhaust, VictoryHID Cyclops
2004 Kingpin - Traded
Term is offline
post #9 of 16 (permalink) Old 09-17-2013, 11:32 AM
with a tooth brush clean the belt every oil change. Soap water scrub and do pulley.
If you keep it adjusted properly you should get 75 thousand out of it if not more.
A belt is not cheap $275
post #10 of 16 (permalink) Old 09-17-2013, 02:36 PM
Neither is a chain\sprocket and they don't last as long!
If you're concerned, replace it. Keep the old as a spare.
jmlmjmjm is offline
