2003-2005 Stage 1 kit work on a 2007? - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 06-26-2014, 05:13 PM Thread Starter
Default 2003-2005 Stage 1 kit work on a 2007?
Will a Stage 1 kit of mufflers, air and efi chip work on a 2007 Kingpin? Like this set here:
http://www.ebay.com/itm/OEM-Victory-...-/181395759042
kevdog is offline
post #2 of 7 (permalink) Old 06-26-2014, 05:40 PM
vindex1963's Avatar
Here's hoping for you that looks like a very good deal. I bet the ECU flash card won't work but I'm guessing.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 7 (permalink) Old 06-26-2014, 06:50 PM
Tarzan's Avatar
Didn't they change the lower rail, so the muffler mount is different?
I know '08 won't interchange.
'14 Ness XC
Tarzan is offline
post #4 of 7 (permalink) Old 06-27-2014, 05:26 PM
KingpinRider's Avatar
My gut feel is no. The 03-05 were 92 cu in motors and the 07 is a newer 100 cu in motor.
2008 Vision Tour Premium - Midnight Cherry
2008 Kingpin Tour - Black & Chrome (SOLD 10/14)
KingpinRider is offline
post #5 of 7 (permalink) Old 06-27-2014, 08:04 PM
king4wd's Avatar
Isn't 07 the year Vic changed over to the closed loop EFI system. I know my 2005 stage 1 has no O2 sensors, but I believe they're on the 07. That open loop/closed loop difference would almost certainly make the ECU map incompatible.
2012 Kingpin
05 Kingpin 50th anniversary edition- Totalled
Adelanto, CA
king4wd is offline
post #6 of 7 (permalink) Old 06-27-2014, 08:32 PM
The 2008's incorporated the closed loop fuel injection. Still has the 100 cu in engine.
post #7 of 7 (permalink) Old 06-28-2014, 07:34 PM
king4wd's Avatar
OK 2008 was the year. My mistake. There is still that 92 to 100 jump and I think you're correct KingpinRider, that may be the stumbling block.
2012 Kingpin
Adelanto, CA
king4wd is offline
