Brake light bolts - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 08-17-2014, 12:15 AM Thread Starter
blkb3tty's Avatar
Default Brake light bolts
What are the sizes and threads of the bolts needed to secure the kingpin brake light to the fender? Any help is much appreciated.
'12 Vegas 8-Ball
blkb3tty is offline
post #2 of 6 (permalink) Old 08-17-2014, 11:34 AM
I'm thinking 6mm you could go to hardware store and try one to see
I might be wrong
post #3 of 6 (permalink) Old 08-17-2014, 11:59 AM Thread Starter
blkb3tty's Avatar
I took the fender to the local 6mm seemed to be the right size but wouldn't thread past maybe the first two threads and I didn't want to cross thread it just in case it was some other size.
'12 Vegas 8-Ball
blkb3tty is offline
post #4 of 6 (permalink) Old 08-17-2014, 12:01 PM Thread Starter
blkb3tty's Avatar
If the fender was powder coated will I need to tap the threads?
'12 Vegas 8-Ball
blkb3tty is offline
post #5 of 6 (permalink) Old 08-17-2014, 12:10 PM
Default Possibly
If there is powder coat(paint) in the threads,yes you need to tap the holes. Larger holes the powder shop I have gone to tapes over the holes. If you see powerder coat in the holes it will make the bolts not want to screw in, the paint is thick making the hole smaller.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #6 of 6 (permalink) Old 08-17-2014, 07:11 PM Thread Starter
blkb3tty's Avatar
Thanks VisionJohnny & SpeedBlue. The 6mm worked after I ran a tap through the holes.
'12 Vegas 8-Ball
blkb3tty is offline
