Led Tail Light For Kingpin - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 02-23-2012, 06:28 AM Thread Starter
Default Led Tail Light For Kingpin
I have a 2007 Kingpin and I just bought the replacement 15 led tail light complete with the adapter from Noemtz. It looks like a quality piece. If anyone has experience with removing the tail light on a Kingpin, I would appreciate some tips on how to do it. Of course, its harder to do when laying on the garage floor and trying to manipulate one hand between the tire and inside of the fender. For this reason, I was planning on letting the dealer do it, but if someone can walk me through the process, I would like to try it myself. I appreciate all comments.
2007 Kingpin Deluxe
RP01 is offline
post #2 of 16 (permalink) Old 02-23-2012, 11:19 AM
CrossRoads's Avatar
Hopefully this helps a little.
CrossRoads is offline
post #3 of 16 (permalink) Old 02-23-2012, 02:15 PM
NOEMTZ's Avatar
Easiest way to go would be to remove seat, remove side struts, remove fender bolts, with a buddy helping out..disconnect harness..lift or remove fender to get to all wires. Install everything and reinstall in reverse order.
www.noemtz.com
NOEMTZ is offline
post #4 of 16 (permalink) Old 02-23-2012, 07:07 PM
OkieHoss's Avatar
post a pic of your KP dude..i love them
2013 black XCT.
OkieHoss is offline
post #5 of 16 (permalink) Old 02-24-2012, 07:09 AM
If you go to the trouble of pulling the fender; you might as well install one of those wire protectors that Witchdoctor sells, and maybe Noemtz, so you never have to worry about the tire hitting the wires underneath the fender. Unfortunately the shipping charges are as much as the part just about.
post #6 of 16 (permalink) Old 02-24-2012, 07:15 AM
Noe; is it possible to disconnect the shock and lower the wheel/swingarm down so you can get at everything under the fender?
Or is it best to do as you described and go through everything at this time?
I haven't done this yet so I'm trying to figure out the path of least resistance. Or is it either or kinda thing?
post #7 of 16 (permalink) Old 02-24-2012, 11:31 AM
I did this same install and found it easier just to remove the fender. It seems like there was an extra nut or two under there to get out. It was much easier to see everything with it removed.
jmholland is offline
post #8 of 16 (permalink) Old 02-24-2012, 11:46 AM
NOEMTZ's Avatar
Easiest to remove fender. And can be done while on kickstand for those that do not have jack or lift.
www.noemtz.com
NOEMTZ is offline
post #9 of 16 (permalink) Old 02-24-2012, 04:56 PM Thread Starter
Thanks for the replies. According to the instructions, there is one bolt to take off behind the fender and the light should come out. The problem is getting at the bolt, there is a metal shield over the assembly. It could be bent out of the way I guess. Nothing I have seen elsewhere indicates the need to take the fender off. If it becomes problematic, I will let the dealer do it. I'm too old to spend a day doing a half hour job.
2007 Kingpin Deluxe
RP01 is offline
post #10 of 16 (permalink) Old 02-24-2012, 05:00 PM
New Member
Got a link for that?
TrashmanNYC is offline
