my take on torque tubes.... - Victory Forums - Victory Motorcycle Forum
post #1 of 145 (permalink) Old 03-22-2012, 10:15 PM Thread Starter
DerekBlk07Vegas's Avatar
Default my take on torque tubes....
SO I finally got my bike back together and my take on cleaning up the frame where the spine and downtubes meet over the front cylinder... enjoy!
DerekBlk07Vegas is offline
post #2 of 145 (permalink) Old 03-22-2012, 10:18 PM Thread Starter
everything being fitted back on.....
post #3 of 145 (permalink) Old 03-22-2012, 10:22 PM Thread Starter
all the orange stuff is engine gasket sealer. i have a filter wrap coming in tomorrow in case i run into excessive rain. i also added a crackcase breather filter as you can see, that's the grey filter.
everything works great and it's really an easy project with the right tools and a day or so to sit down and do it.
post #4 of 145 (permalink) Old 03-25-2012, 08:46 PM
MUDN72's Avatar
Nice work! Did you notice an increase in performance?
2004 Vegas: Ness intake, RPW Thor 2-1, PC3, lowered, Kingpin front end, lots of powdercoating.
*12.18 @ 108 mph with Stage 1 slip-ons and wire rims.
*12.26 @ 113.5 mph with Thor 2-1 and cast rims.
In the works: Barnett clutch, Stingray wheels, WOT box, 20 hp wet shot.
MUDN72 is offline
post #5 of 145 (permalink) Old 03-25-2012, 10:45 PM Thread Starter
I've only ridden it for about 20 miles and haven't been riding hard, there's still alot of gravel in places. I did notice that it doesn't seem to pop as much and it fired right up with out having to be idled up. which is something that doesn't happen for me very often in cooler weather. i'll report back once i do a little more riding.
post #6 of 145 (permalink) Old 03-26-2012, 07:54 PM
New Member
I thought the torque tubes had two separate cone filters?
TrashmanNYC is offline
post #7 of 145 (permalink) Old 03-26-2012, 10:16 PM Thread Starter
they do, but i couldn't see spending $30/filter when i could get one for $30.
post #8 of 145 (permalink) Old 03-27-2012, 03:44 AM
New Member
Gotcha.
post #9 of 145 (permalink) Old 03-27-2012, 04:32 AM
Nice job!
I can't imagine a scenario where you rode in so much rain that it would get into the filter where it's at. It's extremely well protected under there.
post #10 of 145 (permalink) Old 03-27-2012, 09:50 AM
half_crazy's Avatar
How can you tell if you'll get more airflow.... let's see...
The tubes are stock so no change there.
Measure how many square inches of filter media you had with the flat panel K&N filter.
Measure how many square inches of filter media you have with the oval K&N filter.
If the new filter gives more area of filter media, it will potentally flow more air.
Even if the 2 filters are equal in media area, the new filter is unobstructed by the airbox/inlets to airbox (So to make everything equal the stock airbox might need to be rather generously perforated in front of the filter with a drill bit/holesaw to eliminate inlet restriction).
Then again, using a pod type filter eliminates airbox plenum space (pre-tube). Hard to say what effect that would have.
In any case, interesting mod.
2006 Victory Kingpin
half_crazy is offline
