Vegas 8 Ball Forward Controls - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 01-03-2015, 04:42 PM Thread Starter
Default Vegas 8 Ball Forward Controls
I have a 2008 Victory Vegas 8 Ball that I recently picked up. It was one of those deals that I just couldn't pass up. I'm a taller guy at 6'3" - 6'4" with a 36" inseam (225 lbs) and looking at forward control options. It isn't uncomfortable for me to ride right now in its stock configuration, but I think it would be even better if I had a little more leg stretch. 2", 4", more.....I don't know....
I'm curious what other people are running how it feels, affects balance, control, etc....
Jhaas23 is offline
post #2 of 9 (permalink) Old 01-06-2015, 09:46 PM
Sponkey#1's Avatar
No adverse effects on handling my friend. You are going to need to extend the brake line if you go with 4" extensions.
2012 Vegas Eight ball
Ride hard. Ride safe.
Sponkey#1 is offline
post #3 of 9 (permalink) Old 01-07-2015, 04:46 AM
benm's Avatar
can comment on the 2008 but on the 12 the footpeg brackets are diferent to the jackpot/hammer wich gives 2'' and then you can get relocation kit from vic for 2 inches more .
at 6 foot 3 .you would have no probs with 4 inches or even 6
im stuck at 2 as i have a crash bar
2012 vegas 8ball, k&n filter,
rpw thor, wiseco fuel control.
Torque tube intake,
Wilbers shock, gold valve emulators ,
Batwing ,cruise control.
benm is offline
post #4 of 9 (permalink) Old 01-07-2015, 07:29 AM
Motorbikerx's Avatar
cant you mount highway pegs off the crashbar?
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 9 (permalink) Old 01-07-2015, 06:05 PM
benm's Avatar
yes you could put highway pegs on the crash bar but you then have to shift your feet to brake change gear ect.
it is a lindby with a built in foot support on top wich I sometimes use on the freeways.
but what I was meaning was at anymore than 2 inches and my feet touch the bar during gear changes ect
Torque tube intake,
benm is offline
post #6 of 9 (permalink) Old 01-12-2015, 09:03 AM
I have the 2 inch extension. Makes much more of a difference than I ever thought it would. You slightly gotta mess with adjusting the brake line to fit it right. The 4 inch extensions get pretty invasive with cutting the brake line, then bleeding it so I stayed away from that.
dtrow24 is offline
post #7 of 9 (permalink) Old 04-05-2015, 08:34 PM
DVega's Avatar
Hey I have a question for you. How long of a shift linkage did you have to install? I was just about to do my left side, but the shorter linkage in the pack that I have is 9 inches long...my stock one is like 4.5 inches...seems like a 7 would work best...little help?
Fuck victory
DVega is offline
post #8 of 9 (permalink) Old 04-05-2015, 08:54 PM
Dvega. I don't remember what the size was. Mine came in a kit. 9 inches seems a bit long though. I ordered from kewlmetal.
dtrow24 is offline
post #9 of 9 (permalink) Old 05-31-2015, 01:08 PM Thread Starter
I pulled the trigger and installed the 4" extensions. It was a huge improvement. Now if I could just find a way to make some highway bars work in conjunction with these 4" forward controls.
Has anyone figured out a way to accomplish this?
Jhaas23 is offline
