Cruise control on my 2011 - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 06-23-2012, 08:40 AM Thread Starter
Default Cruise control on my 2011
Hey guys, is cruise control a simple plug in on my 2011 Vegas 8ball or do I need to run switches from clutch and brake? Also does the switch housing come in black?
carson1219 is offline
post #2 of 6 (permalink) Old 06-23-2012, 11:00 AM
So you want to spend 500 bucks yes there is wiring involved.
You could use Witchdoctor cruise control for a lot less money and have the same befit's
http://buywitchdoctors.com/index.htm...cruise+control
post #3 of 6 (permalink) Old 06-28-2012, 03:26 PM
ChiTownVegas's Avatar
Just to note... throttle locks are not "the same" as cruise control. If you go up/down a hill, speed will certainly change.
To the OP, I'd call the dealer and see what all is included with the system. I've considered this myself.
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #4 of 6 (permalink) Old 06-28-2012, 06:35 PM
gibson's Avatar
mounts on the bar fed down the bar under tank to the fuse box. That is where the power for the module is. I can not find it in the manual so it must come with instructions.. clutch brake switches are already in the system so it just plugs in. One guy in Canada had problems with his early in the year, you have to do a search to find it.
2012 Fireball Jackpot
gibson is offline
post #5 of 6 (permalink) Old 06-28-2012, 06:40 PM
gibson's Avatar
http://www.brakeawayproducts.com/app...=6&model_id=29 this is what I am going to buy. I do not think I like how the cruise is mounted..
gibson is offline
post #6 of 6 (permalink) Old 07-09-2012, 03:38 PM Thread Starter
thanks Gibson i just took along ride and wished i had cruise control
