Installing Beacon LED headlight help needed - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 03-21-2015, 08:20 AM Thread Starter
Default Installing Beacon LED headlight help needed
I picked up one of the new LED headlight units to install in my Vegas 8-ball, but have (so far) been defeated in removing the little phillips head screw that holds the bottom of the old headlight unit in the housing. Due to the yoke, I cannot get a screwdriver perpendicular to it and only at about 45 degrees. It is screwed it so tight it will not budge at that angle. Anyone have any ideas on how to access and remove this little bu*ger?
ukflyer is offline
post #2 of 6 (permalink) Old 03-22-2015, 12:27 PM Thread Starter
Ok. I had to loosen off the allen bolt and swing the assembly up to get that screw out. The LED is now installed and I hope the beam is aligned back ok. Will find out tomorrow. Before and after pics.
ukflyer is offline
post #3 of 6 (permalink) Old 03-22-2015, 01:21 PM
Hemidan's Avatar
nice...let us know how you like it and if you had to re-align it
2010 CR - D&D pipes unwrapped / Lloydz Performance Cams / Lloyd'z Idle Air Valve / Lloydz Adjustable Timing System / Lloydz Hi-Flow Air Filter / PCV w/AT / Vintage Mustang Seat w/backrest / Lock Ride Passenger Backrest / Powerlet Handlebar Outlet / Lay down License Bracket / Adjustable Drop Bracket
Avon Velvet Air Cushion Gatlin Grips/DERBY COVER & CAM COVER SET/Beacon LED Headlight Black
Phase 7 L.E.D. 4-1/2" Passing Lamps/Sabertooth Taillight Accents
Hemidan is offline
post #4 of 6 (permalink) Old 03-22-2015, 02:58 PM
gee realign would be sitting on bike moving light up or down. Not hard look in owners book on how to
post #5 of 6 (permalink) Old 04-05-2015, 07:55 PM
I just installed the black led victory healight on my 8 ball. Do you have a dark spot directly in front of the bike for aproximately 5 feet before the beam starts? Even with my light aimed all the way down I can't get that dark spot to go away... think it is just designed that way.
jzales84 is offline
post #6 of 6 (permalink) Old 04-05-2015, 08:45 PM
BP6666VR's Avatar
Lools cool mate , like a bat-light only then for victory ja ha
Cross Country Tour 2014 [B]
BP6666VR is offline
