bought my 07 Vegas, now the questions begin - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 07-22-2012, 10:32 AM Thread Starter
dtmmil's Avatar
Default bought my 07 Vegas, now the questions begin
Ok, I have a little bit of a list here.
1- Is there a downloadable manual anywhere for this?
2-How often should the oil be changed, what oil and filter is suggested to be used, do I have to stick with the polaris stuff?
3-whats the easiest way to adjust the rear shock, mine is real stiff.
4-handlebar options, how tall can I go with stock cables and wiring? I was thinking of taking off the stock riser/pullback and putting on just a riser and maybe some 10" mini apes to get the bars to a more comfy position.
5-footpeg relocation, what is available to move them forward a couple inches?
6-lowering the rear, what can be done, I have seen some brackets that must move the rear shock mount to lower it 1" or more, I also noticed that the newer vegas must sit lower?
7-how tight does the belt need to be? It appears that when the last person adjusted the belt if ever, it go just a bit off because the belt seems to be riding on the outer lip of the rear pulley and not the middle.
8-how tight does the rear axle nut get torqued?
Thanks for any help, some of this could be answered if I had a manual. I rode it home from Mies Outland near St. Cloud MN via Brainerd and it is very impressive, the power it has even in OD, the exhaust sounds great! And I got just shy of 49mpg doing mostly 75 on the way home. Just need to make some adjustments to fit me, Im a tinkerer!
dtmmil is offline
post #2 of 4 (permalink) Old 07-22-2012, 11:57 AM
Go to the top of the page and do a search.
You can find a shop manual to down load.
you go here sign up and find the owners manual that will explain features and oil change http://www.victorymotorcycles.com/en...Owners_Manuals
post #3 of 4 (permalink) Old 07-22-2012, 05:27 PM Thread Starter
dtmmil's Avatar
Ok, got answers to 1,3,7,8, now to do some searching for the rest.
dtmmil is offline
post #4 of 4 (permalink) Old 07-23-2012, 07:47 PM
Default Accessories
Two good places IMO is victoryonly.com and conquest customs?
As far as performance, Lloyd's motorworkz
2011 Vegas 8-ball. RPW slash cuts, VM1 cams, Lloyds intake, PCV, Ness fly bars, Ness Holeshot pegs and grips. MBW led turn signals, 4" forward controls, HIDS from victoryhid.com. 115hp/122 lbs. torque
carson1219 is offline
