Shudder at low speed? normal? - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 07-27-2012, 09:14 PM Thread Starter
dtmmil's Avatar
Default Shudder at low speed? normal?
I noticed at low speed, especially on take off, or if I shift to 2nd a little soon, it will kinda shudder, is this normal, if not, whats up? Its done it since I got it, I have changed oil and slightly adjusted the clutch, it hasn't made any difference. If its normal, fine, if its not, I would like to fix it, thanks.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #2 of 8 (permalink) Old 07-27-2012, 09:44 PM
Bad V V's Avatar
If you are shifting before the proper rpm it is normal. You are lugging the engine. You'll have the same shudder if you shift from second third to soon, third the fourth and so on.
2003 Victory vegas
Bad V V is offline
post #3 of 8 (permalink) Old 07-27-2012, 09:47 PM
Normal... RPM's to low
Dave
2012 Cross Country
Jackpot RI is offline
post #4 of 8 (permalink) Old 07-27-2012, 10:24 PM
TJdehya's Avatar
This is what happens in any vehicle with manual transmission when you shift too early.
Current Bikes:
2011 Victory Hammer S (Cobra Tri-Pro Stage1 Exhaust, Blacked out Victory Comfort Grips, Victory Letters Badge) https://www.victoryforums.com/showthr...5948#post95948
2012 Honda CBR1000RR http://www.youtube.com/user/tjdehya?feature=mhee
Previous Bikes:
2002 Honda CBR600f4i
2007 Honda CBR1000RR
TJdehya is offline
post #5 of 8 (permalink) Old 07-27-2012, 10:34 PM Thread Starter
dtmmil's Avatar
Thanks guys, I must just notice it more on this bike for some reason, never noticed it much, or this much on any other bike, but the motor was half this size also.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #6 of 8 (permalink) Old 07-27-2012, 10:52 PM
Bad V V's Avatar
Single over head cam engines are built be high revving engines. @ 3000 rpm you are just getting in to your power band so don't be afrai to let the engine get up to its sweet spot.
Here is a little tip..if you think engine is revving high keep twisting that throttle.
My motto is redline every shift.
2003 Victory vegas
Bad V V is offline
post #7 of 8 (permalink) Old 07-29-2012, 12:32 AM
I find that about 2800 rpm is the optimum shift point for this engine. It also let's the tranny shift smoother. I came from 4 HD's and its tough to get used to letting it breathe a bit. You could shift those things at 1800.
2012 Vegas -D&D slipons, Victory Mini Standard, Tomahawk Bar and rack
2013 GT500
All the toys I need...
USMC341 is offline
post #8 of 8 (permalink) Old 07-30-2012, 12:02 AM Thread Starter
dtmmil's Avatar
My other bike is a 78cb750, generally cruises down the highway at around 5,000 rpms, so this is easy compared to that, thanks!
currently bikeless
Hawley MN(sold)
dtmmil is offline
