Problem with MBW Load Equalizer on 07 Vegas - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 08-11-2012, 02:59 PM Thread Starter
whatcaneyedo's Avatar
Default Problem with MBW Load Equalizer on 07 Vegas
This weekend I've been installing a set of MBW turn signals on my 2007 Vegas. I've put both the fork wrap around ones and the rear fender one on. MBW says that when both are used I should also install a Load equalizer to maintain the bikes stock flash rate. Here is some product information: http://www.mbwmotorcycle.com/products/Vegas.html
The problem that I'm having is that when I installed the Load Equalizer all of the turn signals flash when I try to use the left or right turn signals independently. Its as if I've turned on the 4-way flasher but I haven't. Now, without the Load Equalizer installed the signals seem to work fine although I suppose they're a little fast. The picture shows how I have it wired. Black to black, yellow to blue and yellow to blue with a red stripe.
Have I done something wrong? Or is this maybe a faulty unit? I guess the easy solution would be to just uninstall the Load Equalizer but that seems contradictory to the manufacturers recommendation.
whatcaneyedo is offline
post #2 of 5 (permalink) Old 08-12-2012, 01:13 AM Thread Starter
Never mind folks I've answered my own question. I did a few searches and found an older version of the installation instructions which specify to tap into the wire that is black with a white stripe. Which I did and now everything works as it should. Here is the old version http://www.customdynamics.com/pdf/v4807.pdf
post #3 of 5 (permalink) Old 04-20-2014, 01:43 PM
Xtian's Avatar
I'm thinking of ordering these for my 08 vegas low, just commenting here so that I know where to find this info if I need it
Xtian is offline
post #4 of 5 (permalink) Old 04-20-2014, 05:39 PM
Konga63's Avatar
Hey, if you haven't done so already, you would be well served to download your model's owner manual as it contains the wire diagram for the ACM (in addition to loads of other good stuff): https://www.victoryforums.com/showthread.php?t=10829
2007 Ness Jackpot
Konga63 is offline
post #5 of 5 (permalink) Old 04-20-2014, 07:12 PM
Xtian's Avatar
Thank you for that. I'm downloading it now.
Xtian is offline
