Side Case Re-assembly - Victory Forums - Victory Motorcycle Forum
post #1 of 1 (permalink) Old 05-22-2015, 05:09 PM Thread Starter
Default Side Case Re-assembly
So I recently went down on my '11 Vegas and broke my shifter shaft. So I got the new one and am trying to replace it, unfortunately the old piece came out when I removed the case so I wasn't able to see the old setup. I put everything back together but it doesn't seem like the lever can articulate enough in order to change gears. I started this whole process in neutral if that is important. I assume the piece that points backwards activates the star gear which I assume is what shifts the transmission, but it won't move up or down far enough to move that gear. Help me out here guys, what did I screw up? Any help is appreciated.
4x4ford33 is offline
