rear tire - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 07-12-2015, 06:50 PM Thread Starter
Default rear tire
Stock tire size is 180/55 18...anyone go wider with the stock setup? Pictures and any problems?
Skoglunc is offline
post #2 of 21 (permalink) Old 07-12-2015, 07:58 PM
Motorbikerx's Avatar
180 is plenty wide enough, dont see the point,
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 21 (permalink) Old 07-12-2015, 08:30 PM Thread Starter
You might now see the point but that doesn't help to be completely honest. I do see the point and I like wider tires, so I'm asking for anyone that has done wider tires. Thank you
Skoglunc is offline
post #4 of 21 (permalink) Old 07-12-2015, 08:53 PM
No need to thank me for bumping your post up.
Victory make/ produce/engineer many and varied style of bike to suit a wide variety if tastes and styles.
Granted not everyone wants the same as everyone else, thats why many of us chose a Vic in the first place.
If I personally craved a wide rear Id choose a Jackpot or Hammer or HammerS as my starting point.
Its possible to engineer a Hammers rear into a Vegas but time and moneywise theres better cheaper alternatives.
You may be able to get a 190 or 200 in there but everythings gonna run awful close.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #5 of 21 (permalink) Old 07-12-2015, 09:46 PM Thread Starter
didnt want a hammer or jackpot, I wanted a vegas 8 ball. And I don't need to go up to a 250. Merely wondering if anyone here is running a 200 on a vegas, and if there are any fitment issues.
Skoglunc is offline
post #6 of 21 (permalink) Old 07-13-2015, 12:01 AM
I have read about people running a 200 wide tire but as MotoX said; it's tight. You will also bottom out under the fender easier. A 200 is about 3/4" wider than a 180. Roughly 1/3" wider on each side. Take a look at space between your tire and the belt to see if you have the clearance.
Let us know how it goes...
BBob is online now
post #7 of 21 (permalink) Old 07-14-2015, 11:38 PM
benm's Avatar
the 200 metzler and Dunlop 407 fit just fine ,the Dunlop 407 is a duai compound made for hd ,has Harley Davidson embossed on the side walls ive only done about 600 on mine so far but it feels fine on the road ..
2012 vegas 8ball, k&n filter,
rpw thor, wiseco fuel control.
Torque tube intake,
Wilbers shock, gold valve emulators ,
Batwing ,cruise control.
benm is offline
post #8 of 21 (permalink) Old 07-15-2015, 06:26 AM
If your rim is the newer 5.5" running a 200 will not be an issue. It was an issue with the 5" rim I believe 2010 and older models
muckers is offline
post #9 of 21 (permalink) Old 07-15-2015, 06:27 AM
vindex1963's Avatar
The D407 will last a LOOONG time my Harley Ultra had them and the D407 lasted 19,000 miles on that big heavy bike. The D408F front lasted almost 25,000.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #10 of 21 (permalink) Old 07-15-2015, 11:31 AM
I don't do burnouts or jack rabbit starts, I only get average 7000 miles out of a back tire! I`ve tried every brand out there. Here in Kansas tho, we run 75 to 80 mph all the time. Must be the reason
oldrocker is offline
