Popping Sound - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 11-28-2009, 06:13 PM Thread Starter
Default Popping Sound
Just bought my Vegas on Friday.......Had it out for a ride today and it was popping fairly frequently. Never owned a cruiser so I don't know if this is normal or not. It is brand new (2 miles on it). Any thoughts?
fleeingdemons is offline
post #2 of 13 (permalink) Old 11-28-2009, 06:22 PM
The Diamond
diamondrmp's Avatar
Is it a stock exhaust?
diamondrmp is offline
post #3 of 13 (permalink) Old 11-29-2009, 08:46 AM Thread Starter
Yes, stock exhaust
post #4 of 13 (permalink) Old 11-29-2009, 10:13 AM
CycleOpsUSA's Avatar
Tell your dealer to to a TPS reset on it and see if it improves.
CycleOpsUSA is offline
post #5 of 13 (permalink) Old 11-29-2009, 06:59 PM
The Diamond
diamondrmp's Avatar
If you are running the stock exhaust and it is popping like Will stated have that TPS reset.
post #6 of 13 (permalink) Old 11-29-2009, 11:18 PM
I also read on another forum that it was pretty much normal?
vkray is offline
post #7 of 13 (permalink) Old 11-29-2009, 11:29 PM
The Diamond
diamondrmp's Avatar
Its pretty normal with aftermarket exhaust but if he has the stock setup thats not normal.
post #8 of 13 (permalink) Old 05-01-2010, 11:08 AM
Default Same problem here
I just bought a new 09 Vegas with the stock swept pipes.... frequent "popping" on decel. What's really annoying is that on the 2010 Vegas with the same exhaust that I test drove, there was none whatsoever. I've got the 500mile service coming up soon, I'll bounce the BCU/ TPS issues with the tech..... hopefully he can tweak something. Also, it seems like my belt is rubbing on the outer side of the pulley and not tracking directly down the middle..... is that just an alignment thing or something more sinister like a bad pulley ??
sirdouglas68 is offline
post #9 of 13 (permalink) Old 05-01-2010, 11:18 AM
The Diamond
diamondrmp's Avatar
The belt travel varies on different bikes. Sometimes its alignment and other times its just the way the belt travels on that particular bike.
post #10 of 13 (permalink) Old 05-01-2010, 08:43 PM
kevinx's Avatar
No TPS adjustment possible on the 08 and up bikes. Totally different injection system. On your test ride you prolly rode the 2010 a little more timidly then you do the 09 you have become more familiar with. One thing is certain in the world of Victory. ALL Vic Swept pipes pop like a bitch. You can try unplugging your o2 connectors to reduce it a little. You won't trip a check engine light, and the overall drivability will improve
kevinx is offline
