low beam light and running lights out - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 08-18-2015, 04:50 PM Thread Starter
Default low beam light and running lights out
so went to ride home from work the other night and the low beam light and running lights (turn signals when not flashing...) weren't working. I checked the fuses swapped relays around and nothing... so my next guess is that maybe the low beam light just went out and the running lights are connected to that in some way. turn signals still work fine when the are actually activated same with flashers. and the high beam works fine... what do yall think?
Price1417usn is offline
post #2 of 8 (permalink) Old 08-21-2015, 10:05 AM
ChiTownVegas's Avatar
What year bike???
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #3 of 8 (permalink) Old 08-21-2015, 11:56 AM Thread Starter
2008 vegas low
post #4 of 8 (permalink) Old 08-21-2015, 12:01 PM
pull the bulb and see if its good. Auto store sells them.
You never want running lights on same circuit as headlight
post #5 of 8 (permalink) Old 08-21-2015, 11:58 PM Thread Starter
i agree... just think its kinda weird that they both went out at the same time.... will try the bulb tomorrow and hopefully it works
post #6 of 8 (permalink) Old 08-25-2015, 09:29 PM Thread Starter
Default still no worky
so I replaced the low beam bulb it was burnt out.... however the running lights still don't work... I have check all the fuses and they are all fine.... any other suggestions.... thanks for the help in advance
post #7 of 8 (permalink) Old 08-26-2015, 12:21 AM
Travis P's Avatar
Is that the round headlight? H4 bulbs?
Travis P is offline
post #8 of 8 (permalink) Old 08-26-2015, 07:28 PM Thread Starter
negative it is the bullet with the h7 for the low beam and h11 for the highbeam
2008 vegas low
Alexandria VA
