Can I put a 190 55 18 tire on the rear without any problems - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 10-16-2015, 12:56 PM Thread Starter
GSCHEETAH's Avatar
Default Can I put a 190 55 18 tire on the rear without any problems
I have a 05 Ness Vegas with a 180 55 18 on the rear I would like to put a little wider tire on seen post about 200's poor handling and starting wondering if 190 55 18 work and has anyone tried it. Was there any issues?
GSCHEETAH is offline
post #2 of 11 (permalink) Old 10-16-2015, 01:02 PM
It should work. We are only talking an extra 5mm (less than 1/4") on each side. You won't gain anything in the way of handling though. The 180 is the optimum width for handling.
BBob is online now
post #3 of 11 (permalink) Old 10-16-2015, 02:11 PM Thread Starter
GSCHEETAH's Avatar
It does handle well now but was asking if I might have any problems and may look better with a little wider tire just not sure if I want to be the first to try
post #4 of 11 (permalink) Old 10-16-2015, 02:27 PM
dtmmil's Avatar
it will be slightly taller also
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 11 (permalink) Old 10-16-2015, 02:27 PM
dtmmil's Avatar
where are you finding a 190?
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #6 of 11 (permalink) Old 10-16-2015, 04:59 PM Thread Starter
GSCHEETAH's Avatar
Motorcycle Superstore, but after looking closer. I found them in 17 inch not 18 in all brands looks like it's a 180 for me. but thanks for all the info
post #7 of 11 (permalink) Old 10-16-2015, 06:04 PM
look at dennis kirk or jp cycle you'll find more tires and maybe better prices
post #8 of 11 (permalink) Old 10-16-2015, 07:13 PM
You can also try rocky mountain atv or Jake wilson for tires
vcc14 is offline
post #9 of 11 (permalink) Old 10-19-2015, 01:01 PM
Pheonix's Avatar
I'm sure you can make a 190 fit, BUT:
-It will void the tire warranty if too narrow of a rim per tire manufacturer specs.
-It will sit taller.
-Once you "over-round" the tire to fit, it will probably be narrower than a 180.
-It will handle worse.
-It will wear in the middle quickly.
2011 Kingpin - Scarlett
Stage I Pipes with Thunder Monsters & NO Catcons
Ness Laydown Plate Holder with Custom Dynamics LED Plate Frame
Custom Ness Engine Covers
V92C Floorboards with NON-LOW Mounts
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Dyno Tuned by 804 Motor Sports
97.26 HP / 110.42 # for now...
Pheonix is offline
post #10 of 11 (permalink) Old 12-05-2015, 07:31 AM
If you go up to a 190 I suggest you go down to a 50 profile.
2008 Suzuki B King,2010 Vegas 8 Ball,2006 BMW Z4.
goon is offline
