Front shock rebuild. - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 37 (permalink) Old 10-22-2015, 08:06 AM Thread Starter
Cali Phil's Avatar
Default Front shock rebuild.
Not sure if I am capable or not but have a question. I feel my front shocks seem a little lite when I come to a stop. The front dives more than I would think it should. I may try and get my shocks rebuilt over the winter. Is there anything special I can or should do to the forks IE: special oil, stronger springs etc? Just want the front to feel as plush as possible. Thoughts?
2006 Victory Vegas 8ball Santa Rosa Ripper exhaust, Thirdgear intake, Power Commander 3
I live in beautiful Mount Shasta Calif. Where heaven and Earth meet.
Cali Phil is offline
post #2 of 37 (permalink) Old 10-22-2015, 09:38 AM
BP6666VR's Avatar
There is a few threads on this forum about changing fork oil and rebuild ... Use the search button .
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 37 (permalink) Old 10-22-2015, 10:42 AM
Seeing how yours is a 06 its probably time for new fork fluid.
So you know the front end is supposed to dive as you call it for fast stopping
post #4 of 37 (permalink) Old 10-22-2015, 07:45 PM Thread Starter
Cali Phil's Avatar
I know it should dive. I have never owned a big bike before and I am just unsure of certain characteristics. Like going over certain objects my front just seems like it doesn't soak it up as well as it could. I have only owned the bike a few months and it has 4k miles on it.
post #5 of 37 (permalink) Old 10-22-2015, 09:08 PM
That's awfully low mileage to have to rebuild the forks. Have someone with a similar bike ride yours before you decide to dive into those forks. Not shocks, those are in the rear.
post #6 of 37 (permalink) Old 10-22-2015, 09:46 PM Thread Starter
Cali Phil's Avatar
Sorry I meant forks. I am a moron lol.
post #7 of 37 (permalink) Old 10-22-2015, 11:27 PM
Motorbikerx's Avatar
yeah 4000 miles on an '06...........some people just dont ride!
Im off for a ride
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 37 (permalink) Old 10-23-2015, 06:32 AM Thread Starter
Cali Phil's Avatar
Well the bike was stored for a while and the dust seals are showing some signs of lite cracking. When I go over an abrupt edge the bike feels like it hits hard and rattles a bit. Maybe I expect to much from the forks. I can tell you when I am 2 up the bike does feel somewhat better.
I just had an idea. Perhaps it has to do with the smaller tire that is on the front?
post #9 of 37 (permalink) Old 10-23-2015, 10:05 AM
Does it feel like the forks are bottoming out??
heres a trick..put a zip-tie around your fork tube then go for a ride,
the zip-tie will remain to indicate wherever the furthest fork travel has been.
5.1 inches or 130mm is total travel so if you lean your bike on the sidestand to where the front wheel leaves the ground and have an assistant measure 130mm up from the fork legs lowest point then compare, then youre gonna have a better idea of what range your forks are travelling through .
These bikes are sprung fairly soft really as they're a cruiser, you could go to slightly heavier fork oil or increase the air gap you change the fork oil, both measures together will firm the forks up a little without making them harsh.
I used 10W full synthetic fork oil with a 135mm air gap last time and I'll experiment with 15W and 140mm next time I reckon, as I ride fairly hard.
GatorJoe likes this.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #10 of 37 (permalink) Old 10-23-2015, 12:19 PM
New Member
gard8427's Avatar
Some people over-G their shocks when ratchet strapping their bikes down to a trailer. The fronts are most vulnerable to this condition making them leak and may be the reason for yours feeling sub par.
gard8427 is offline
