Victory Vegas Low Handlebar Position (moving them) - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 10-25-2015, 01:33 PM Thread Starter
DVega's Avatar
Default Victory Vegas Low Handlebar Position (moving them)
tried a search, found nothing.
I want to raise my handlebars to a more upright position like the 8-ball has...so last night I took the controls off only to find that this cannot be done until I drill a second set of holes in the bars so the controls have somewhere to sit in and hold to. Everything I had previously read said the handlebars all come with two sets of holes for either an upright or low riding position depending on rider size. Well that is just not true and I'm tired of pulling my elbows in to ride.
I'd like to see if anyone has done this or who could some approximate estimates as to where I should make these holes in relation to the existing ones so I can keep all my cables at the same length and avoid much adjustment.
Thanks.
Fuck victory
DVega is offline
post #2 of 12 (permalink) Old 10-25-2015, 03:24 PM
It would be much easier to grind down the peg than to drill new holes, don't you agree? Then you can change the angle of the levers to wherever you want. When tightening the perches, have then just tight enough that they hold their position, but can rotate in the event of a drop and prevent the levers from breaking. An old dirt biker's trick.
Three reasons drilling the bar is not a good way to go; chrome is very, very hard stuff, new holes will start it peeling, unless you have a drill press with a drilling jig its hard to start a drill bit on a round surface.
post #3 of 12 (permalink) Old 10-25-2015, 03:30 PM Thread Starter
DVega's Avatar
you are 100% correct...it would definitely be easier to do that, and I did consider it but was unsure if I could tighten them enough to prevent them from moving/sliding. Guess I could wrap the bars with some electrical tape to give the perches something to bit into a tad. \\
...Alright, I'll give it a shot...thanks!
Fuck victory
DVega is offline
post #4 of 12 (permalink) Old 10-25-2015, 03:36 PM
You can tighten 'em stupid tight if you wanted to. No need for tape. I did what I recommended to my bars 5-1/2 years ago and nothing has moved.
post #5 of 12 (permalink) Old 10-25-2015, 03:40 PM Thread Starter
DVega's Avatar
excellent...looks like i have plans tonight!
Fuck victory
DVega is offline
post #6 of 12 (permalink) Old 10-25-2015, 03:53 PM
The perch is made of soft aluminum, so filing the pegs down will be easy. Good luck and glad I could be of help. That's what us old guys hang around for.
post #7 of 12 (permalink) Old 10-25-2015, 09:56 PM
Motorbikerx's Avatar
What RICZ said, thats what I did when I fitted BurleighBars.
Motorbikerx is offline
post #8 of 12 (permalink) Old 10-26-2015, 03:19 AM
BP6666VR's Avatar
I am 6' 3" so i also moved my bars UP same line as my fork, just "snip off" that nodge and file it back, easy peasy
Cross Country Tour 2014 [B]
BP6666VR is offline
post #9 of 12 (permalink) Old 10-26-2015, 08:14 AM
Cali Phil's Avatar
Interesting post and hope I am not hijacking. When I ride 1 up my bike feels ok reach wise to the bars. Not perfect but ok. When I ride with my wife 2 up the problem is more apparent. My wife is constantly sliding forward over bumps because I cannot rest against her as my reach doesn't allow it. How does one determine which bars to get to correct this problem.
2006 Victory Vegas 8ball Santa Rosa Ripper exhaust, Thirdgear intake, Power Commander 3
I live in beautiful Mount Shasta Calif. Where heaven and Earth meet.
Cali Phil is offline
post #10 of 12 (permalink) Old 10-26-2015, 11:37 AM
There should be a generous elbow bend when you are in a riding position. If your arms are straight, or damn near straight, you are too far away from the bars. It's that simple.
I was too far from the bars and when I had my seat customized, he modified it to move me forward. Now I have much more control.
