Newer Vegas fork width - Victory Forums - Victory Motorcycle Forum
post #1 of 28 (permalink) Old 11-11-2015, 12:08 PM Thread Starter
Default Newer Vegas fork width
I'm trying to find a windshield option for my Gunner and I was wondering if I could get a measurement from a newer Vegas? I'm looking for the width of the forks at the triple trees end to end. Thanks in advance!
CeeCab705 is offline
post #2 of 28 (permalink) Old 11-14-2015, 07:29 AM
DVega's Avatar
Hey man, I'll measure mine later this afternoon when I get home from work. I'll also give you the measurements of my victory mini windshield clamps.
Fuck victory
DVega is offline
post #3 of 28 (permalink) Old 11-15-2015, 07:33 AM Thread Starter
Thanks man!
post #4 of 28 (permalink) Old 11-15-2015, 07:59 AM
kevinx's Avatar
43mm if I remember correctly.
kevinx is offline
post #5 of 28 (permalink) Old 11-15-2015, 08:07 AM Thread Starter
I'm looking more for the width between the legs. I ordered a memphis shades kit for a different victory and it is about 2" too narrow. I completely butchered the brackets trying to make it work.
post #6 of 28 (permalink) Old 11-15-2015, 09:59 AM
Motorbikerx's Avatar
"Between the legs"?
"end to end"?
where exactly would you like measured?
43mm is is indeed the diameter of the fork tube @kevinx
I have a 2010 Vegas and would speculate the fork measurements , spacings between the tubes and also between the legs, as well as tube diameter are the same as the latest Vegas.
I could be wrong.
Where exactly would you like measured?
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 28 (permalink) Old 11-15-2015, 10:33 AM Thread Starter
End to end. I just need to figure out what the difference in width is between the Gunner/HB and the Vegas.
post #8 of 28 (permalink) Old 11-15-2015, 11:45 AM
gunner triple tree p/n 5137650-463
high ball triple tree p/n 5137650-463
these 2 are the same. Did you think maybe they sent you wrong part
post #9 of 28 (permalink) Old 11-15-2015, 12:07 PM Thread Starter
I need to compare the gunner/HB to the Vegas front end. They did send me the right part it's just that it did not fit my Gunner and I thought I could modify it. I'm just trying to find a different option than the victory one at more than $500.
post #10 of 28 (permalink) Old 11-15-2015, 04:21 PM
End of what to end of where?
You know exactly where you want measured but its not communicating.
Try posting a pic clearly showing a tape measure on the relevant points.
All those bikes are built from the same Vegas platform so should be the same.
More specific info needed....a pic is ideal.
VJ has already stated the triple tree part nos are the same.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
