Please verify allen wrench size for front axle. - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By Pauljp
post #1 of 10 (permalink) Old 12-14-2015, 06:30 PM Thread Starter
Jae_cubed's Avatar
Default Please verify allen wrench size for front axle.
Can someone please verify the socket is 14mm for the axle for a 2004 Vegas? I did some research and I believe this is the size but before I buy anything I'd like to verify it.
Thanks in advance.
Upsate NY
2004 Victory Vegas
Jae_cubed is offline
post #2 of 10 (permalink) Old 12-14-2015, 06:34 PM
Motorbikerx's Avatar
Thanks in advance.
14mm on my 2010 Vegas.
Need to verify just grab a 14mm bolt head and see if it fits in.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 10 (permalink) Old 12-14-2015, 07:16 PM Thread Starter
Jae_cubed's Avatar
Thanks Motorbikerx will try that.
Upsate NY
2004 Victory Vegas
post #4 of 10 (permalink) Old 12-14-2015, 07:47 PM
Before you go and buy an expensive 14 mm Allen wrench or Allen wrench socket, be aware that you can use the appropriate size threaded rod coupling nut instead. Half the coupling nut fits inside the axle and the other half hangs out to be turned by a socket that you undoubtedly already have. This is a $2 fix instead of a lot more for an allen wrench. In addition, you can easily use a torque wrench on the socket that is turning the coupling nut whereas you can't really use a torque wrench with an Allen wrench unless you get the Allen wrench socket.
G'day,
Vinish
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #5 of 10 (permalink) Old 12-14-2015, 09:28 PM
DirtyDan's Avatar
G'day,
Vinish
Yep. When pulling my front end apart yesterday it was oh shit time, I don't have that size Allen wrench. My buddy looked around and there on the lift was a long drift I had used for something else. It had a 6 sided flat portion cut into the handle. He popped it in the axle and it was just a hair small but it did the job.
There you go.
Dan
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #6 of 10 (permalink) Old 12-15-2015, 12:04 PM
5/8's or 14mm I believe for late models
Hardware stores have coupling nuts.
Value Brand Rod Coupling Nut, Grd 2, 1/2-13, Pk10 1JA77 | Zoro.com
post #7 of 10 (permalink) Old 12-15-2015, 02:59 PM
Pauljp's Avatar
In my wheel removal video located here, go to the 2:10 mark and I show you some other ways that you can take off the axle.
JR_DOG likes this.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #8 of 10 (permalink) Old 12-15-2015, 03:10 PM
LILMAGS500's Avatar
I think the 5/8's is = to 16mm
LILMAGS500 is offline
post #9 of 10 (permalink) Old 12-15-2015, 06:41 PM
MLR1's Avatar
14 mm on my 03, so should be the same. I bought a set at Harbor Freight for under $30 that have held up just fine.
2010 Cross Roads, Midnight Cherry, PCV, LSC cams, Lloydz filter, ADJ timing wheel @+4, Home built mufflers....
2009 Vision Tour Premium, Black/Silver, PCV, HPT cams, Lloydz top filter, ADJ timing wheel @+2, Home built mufflers....
2003 Vegas, Solar Red, PCIII, Home made TT, Ness Swept exhaust, Custom Luggage Rack.... (sold)
MLR1 is offline
post #10 of 10 (permalink) Old 12-15-2015, 07:04 PM
I just bought the one good quality 14mm Allen key socket 1/2" drive.
