Right blinker stuck flashing - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 05-23-2016, 11:14 AM Thread Starter
Default Right blinker stuck flashing
I have a 2009 Vegas that has the right side blinker keeps blinking and won't shut off. It won't clear if I push the signal button in. It does have the feature where it turns off by itself (I assume that is called auto canceling?) But nothing works. It won't shutoff it I turn the button the left and then back. I tried disconnecting the battery in hopes it would reset something.
I can say I generally push the signal button in to cancel the signal after I turn, because this is the first motorcycle I have ever had that has the auto cancel feature so I always forget. I can't imagine I wore something out in the switch.
I'm stuck at work so I haven't even taken the switch apart yet to see if there is anything obvious. I was just wondering if anyone has had a similar issue and I was wondering where to start.
Also, I'm ready for the jokes. Yes I can always just turn right. And the blinker fluid is topped off.
alm70 is offline
post #2 of 7 (permalink) Old 05-23-2016, 04:41 PM
Sponkey#1's Avatar
Well, you covered my smartass reply so I'll just say good luck.
2012 Vegas Eight ball
Ride hard. Ride safe.
Sponkey#1 is offline
post #3 of 7 (permalink) Old 05-23-2016, 05:48 PM
Honda East Toledo's Avatar
Has it gotten wet or water in it lately?
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #4 of 7 (permalink) Old 05-23-2016, 05:53 PM
My blinkers act up from time to time. I believe the switch gets wet, then dirt collects. I spray some electrical contact cleaner in the switch and it fixes it up.
PaiN is online now
post #5 of 7 (permalink) Old 05-23-2016, 05:53 PM
BlueVegas's Avatar
Does the left signal work properly? What about the 4 ways?
BlueVegas is offline
post #6 of 7 (permalink) Old 05-23-2016, 06:46 PM
did you add LED blinkers
post #7 of 7 (permalink) Old 05-24-2016, 11:07 AM Thread Starter
update:
Thanks everyone for quick replies. I was able to fix it last night and I believe there was some moisture and/or dirt in the switch as a few of you suggested. I took casing apart that holds the switch
and kind of moved some things around, and sprayed some electrical contact cleaner as PaiN mentioned above and after putting it back together it worked fine. I never checked to see if the four-ways worked,
but that would of been a good test.
Sorry for the panic. This happened on my way to work yesterday and it was driving me crazy all day thinking about what the cause could be. I'm back on the road!
alm70 is offline
