Power Ports - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 11 (permalink) Old 05-25-2016, 02:51 PM Thread Starter
Parajoe's Avatar
Default Power Ports
Anybody got a power port on their Vegas for charging cell phones, or heated accessories? Which one did you use, and where did you route it? I'd like to put a RAM mount on the handle bars with power routed to it, but I would like to see others' set up. Pics would be cool too.
You deserve what you settle for.
Parajoe is offline
post #2 of 11 (permalink) Old 05-25-2016, 04:24 PM
Right now I ran a batterytender harness (spliced in about 32" of wire to extend), ran under the tank to the area behind the fork. Battery tender has a USB adapter for about $12. I have the RAM as well. a 2 -3' USB is plenty to allow your turns. Total cost about $22. Kuryakyn makes a nice chrome set up that routes the same way for about $48 (seem ot after I did the install and would have gone this way instead).
Spanky1131 is offline
post #3 of 11 (permalink) Old 05-25-2016, 07:24 PM
Judge Redd's Avatar
Main unit (front)
Splitter (goes to the rear- also a dual port)
Sorry no link for the rear unit.. forgot where I got that.. will edit if I can find it..
Pics
Tips and such:
Removed tank- ran wires alongside bikes big harness- zip ties, etc. leave a little slack up front to allow for full handlebar travel with NO stress on wire, and out back for the user- if applicable. Carefully arranged excess in safe area and secured. The back unit holds fast to the seat bracket with a magnet (from a name tag) hidden with a thin wrap of electrical tape.
DO NOT HOOK a USB port DIRECTLY TO BATTERY. Tap into a wire hot with ignition only. They WILL suck your battery DEAD in HOURS. It is unlikely to be recoverable.
wspollack likes this.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #4 of 11 (permalink) Old 05-25-2016, 08:13 PM Thread Starter
Parajoe's Avatar
On my last bike I ran everything to a relay that only worked when the bike was on, so I will probably do that on this one too. Just looking for ideas.
Parajoe is offline
post #5 of 11 (permalink) Old 05-25-2016, 08:33 PM
LILMAGS500's Avatar
I had this on my 2013 Hammer and loved it , Top quality products from powerlet , this is really your best option for a power outlet with the ram mount .
Powerbar Plus 7/8" To 1" Black Anodized w/ RAM Ball - Powerlet Products
matsekberg likes this.
LILMAGS500 is offline
post #6 of 11 (permalink) Old 03-20-2017, 06:29 PM
Originally Posted by Judge Redd View Post
Main unit (front)
Pics
Tips and such:
Where did you connect the converter to?
Skickat från min iPhone med Tapatalk
matsekberg is offline
post #7 of 11 (permalink) Old 03-20-2017, 06:41 PM
Judge Redd's Avatar
I think I deleted the photo, but under my seat were a couple of leads with capped connectors. These are just part of the standard manufacturing process. An orange and a purple, I think. Confirmed hot with key only with my test light, Snipped & stripped off the battery post loop on the chargers positive wire and wiretapped the purple one.
Ah ha- found them
post #8 of 11 (permalink) Old 03-21-2017, 05:47 PM
Ah ha- found them
The orange 2-pin connector is a Bosch fuel injection type connector #1928403137
Like this https://www.ebay.co.uk/itm/131468016712
post #9 of 11 (permalink) Old 03-22-2017, 06:11 PM
And the other one is a Delphi 280 series http://www.mouser.se/Search/m_Produc...ey829-15300003
post #10 of 11 (permalink) Old 03-26-2017, 11:22 AM
I made a 3D printed connector for the 12v to USB converter.
