Turn signal conversion to LED - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 02-01-2010, 10:46 PM Thread Starter
New Member
Default Turn signal conversion to LED
I'm wanting to replace the stock halogens with LED turn signals in the rear, probably front later. Is this difficult?
Also, How difficult is it to wire LEDs as run/brake and signals?
(Newbie here, 2008 Vegas Premium, Midnight Cherry)
Jwunder is offline
post #2 of 10 (permalink) Old 02-01-2010, 11:02 PM
The Diamond
diamondrmp's Avatar
diamondrmp is offline
post #3 of 10 (permalink) Old 02-02-2010, 02:20 PM
allenterry's Avatar
I used the Custom Dynamics kit for the LED signals, it was very easy and looks great, you will need to order the resistor pack from them as well to keep the stock signal flash rate.
http://www.customdynamics.com/victor...gnal_array.htm
allenterry is offline
post #4 of 10 (permalink) Old 02-03-2010, 08:37 PM
So do I need the resistor pack for just the rear l.e.d light bar and I would be keeping the stock front signals.
SgtDan is offline
post #5 of 10 (permalink) Old 02-03-2010, 09:47 PM
allenterry's Avatar
Yes, the bikes with the self-canceling signals ('05 and newer) need the correct resistance for the system to operate as it should. What I called a resistor pack they call a load equalizer, but that is whet it is resistors. It is a very simple install.
http://www.customdynamics.com/loadequalizer.htm
post #6 of 10 (permalink) Old 02-04-2010, 08:48 PM
bfernandez's Avatar
[email protected]
I emailed custom dynamics talked with Dave, he said if you are only doing rears you do not need load equalizer. If you do both front and rear lights then you do need it. May want to email him to verify. I am new to forum, you all have great info. here! '06 Jackpot owner.
bfernandez is offline
post #7 of 10 (permalink) Old 02-05-2010, 07:59 AM
allenterry's Avatar
That makes sense, I converted both and am very happy with them.
post #8 of 10 (permalink) Old 02-05-2010, 08:39 PM
That is what I thought, but tomorrow I will be at the International Bike Show, so I will be hitting up the Victory table.
SgtDan is offline
post #9 of 10 (permalink) Old 02-06-2010, 06:18 AM
bfernandez's Avatar
Please let us know what you find out. I plan on doing this to my bike next month. May as well do it right the first time you know what I mean. I am hitting a bike swap meet today in syracuse, hopefully will find some lights and different ideas for the jackpot.
post #10 of 10 (permalink) Old 02-07-2010, 10:33 AM
I did just the rear,s with the mbw wrap around led,s . the flash rate was faster but the self canceler still worked. I am in process of doing fronts now and just purchesed the load equalizer.
Dave is offline
