Replacing clutch cable - Victory Forums - Victory Motorcycle Forum
 5Likes
  • 1 Post By visionjohnny
  • 1 Post By BrianT
  • 1 Post By rainman123
  • 1 Post By BP6666VR
post #1 of 10 (permalink) Old 01-15-2017, 09:02 PM Thread Starter
rainman123's Avatar
Default Replacing clutch cable
Need a little help next weekend I'm planning on replacing the clutch cable on 2011 Vegas 8 ball am I gonna have to take the gas tank off to run the cable
What is the easiest way to do it they are a couple nuts that is hard to get to
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #2 of 10 (permalink) Old 01-16-2017, 01:04 PM
Wormjello likes this.
visionjohnny is online now
post #3 of 10 (permalink) Old 01-16-2017, 03:02 PM
anyone done the hydrolic clutch set up?
Tim Johnston is offline
post #4 of 10 (permalink) Old 01-16-2017, 06:32 PM
Originally Posted by Tim Johnston View Post
anyone done the hydraulic clutch set up?
yes a few have. witchdoctor is the place to go. Double measure the length of hose you need
post #5 of 10 (permalink) Old 01-16-2017, 07:50 PM
I recently replaced the clutch cable on my 2009 Vegas and the WitchDoctor video helped a lot. I had to remove the tank. I replaced the OEM one with the Barnett cable 101-85-10008. While I had the tank off, I also routed a powerlet port to the handlebar.
rainman123 likes this.
2009 Victory Vegas
Shotgun Exhaust
Morris, NJ
BrianT is offline
post #6 of 10 (permalink) Old 02-08-2017, 05:32 AM Thread Starter
rainman123's Avatar
Finally replaced the clutch cable on my girlfriend Vegas and it was aggravated as hell to do if it brakes again I think I'll go to Lowe's and get a cable and cable stops to fix it as a few had suggested
Anyway got on and she finally rode it Sunday and all is good the clutch wasn't slipping so that is a relief that I won't have to change the clutches
2012 crossroad
73 sportster sold
06 rocket3 classic
post #7 of 10 (permalink) Old 02-08-2017, 06:06 AM
Motorbikerx's Avatar
Just fitted a Barnett plus 6" to my Vegas, the price was right and the extra length fits my Burleigh Bars better, standard one just reached pulled tight and worked ok but with my new Scorpion I wanted the clutch pull as forgiving as possible.
Its fairly easy with the tank off...Just mentally doing it in my head with the tank on...problems.
Firstly to remove the old one because of the adjuster part and curved metal sheathing there's on way to pull it through and out the top..if you could you'd connect the new cable to the old and use the old one to pull it through...not possible.
ok try the other way...pull the old one down and out the bottom but same problem because of the adjuster and curved metal sheathing you cant connect to the old cable and pull it down either.
Stalemate either way.....to put it simply No you can't.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 10 (permalink) Old 02-09-2017, 05:00 AM Thread Starter
rainman123's Avatar
What I did was tied a string to the end of the clutch lever side and pulled the cable through then disconnected it at the trans which I kept the tank on then tied the sting to the new cable and pulled it back through the worst part was trying to get the end back through the hole in front
Motorbikerx likes this.
2012 crossroad
73 sportster sold
06 rocket3 classic
post #9 of 10 (permalink) Old 02-09-2017, 05:24 AM
BP6666VR's Avatar
1 year ago I change for Barney clutch and I lifted the tank only on the seat-side, the tripletree side I just loosen the bolts, but is was super difficult to cut all the cable ty so then I just removed the tank, ya ha ha... Not an easy job but a bit of patience and a few beers and it was finished
Andre
TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #10 of 10 (permalink) Old 02-09-2017, 12:00 PM
how ever you did it is good. But
every oil change clean and lube to prevent braking
