fuel injection/pump problem? - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 1 Post By swiftdescent
  • 1 Post By PaiN
  • 1 Post By visionjohnny
post #1 of 4 (permalink) Old 06-03-2017, 08:33 PM Thread Starter
Default fuel injection/pump problem?
New to me 2005 Vegas (my first ever Victory, so not very familiar with them). The only upgrade I am familiar with on the bike is it has the Stage 1 Victory Performance Pipes. The bike has 12k miles and I have cleaned the throttle body already. So here's my issue: When the fuel falls to under half a tank, or I get around 90-100 miles ridden on a tank, the bike really sputters while at idle, like it is struggling to get gas. Once I get going its fine. But if I'm sitting at a stop light, I really have to rev it and over-rev it to get going or it will stall out. Full tank of gas, no issues. Again, it seems to occur when I get to under 1/2 a tank, or around 90-100 miles ridden.
So I'm thinking I may have an issue with the fuel pump and/or injectors? Or does anyone have any other suggestions on what it might be?
Thank you in advance for any help.
50btripn is offline
post #2 of 4 (permalink) Old 06-04-2017, 03:57 AM
I'm no mechanic, so here's my stab in the dark - Dirty fuel filter?
50btripn likes this.
2015 Gunner Titanium - Arlen Ness Ram Air intake, Hacker Rippers, PCV w/Autotune
2017 Magnum Black/w Graphics - Stage 1, S&S Cams, Triovals
swiftdescent is offline
post #3 of 4 (permalink) Old 06-04-2017, 07:21 AM
@50btripn You might want to run a good dose of Sea-Foam or some other quality fuel system clearer\conditioner through as a first step. I'm not sure if an adjustable IAV can be used on an 05 but a call to Lloydz wouldn't hurt. 12k miles is early for a fuel filter change but your Vegas is older so that might be an option. Beyond that, maybe the bike is not tuned right for the pipes and a fuel controller and proper tune might help and give you more power to boot
https://lloydz.com/products/intake-a...dle-air-valve/
https://lloydz.com/products/intake-a...gen-3-vfc-iii/
post #4 of 4 (permalink) Old 06-04-2017, 02:36 PM
I have read where many a guy that has cleaned the throttle bodys has to reset the Throttle Position Sensor yes this is not your model but there all the same. NAPA sells them take old one with you
