FINALLY finished fouling plugs FYI - Victory Forums - Victory Motorcycle Forum
 7Likes
  • 3 Post By robert a
  • 1 Post By Vinish
post #1 of 5 (permalink) Old 09-13-2017, 05:44 PM Thread Starter
Default FINALLY finished fouling plugs FYI
well my 2010 vegas with 18k miles has been down a good part of the summer. One day upon starting it just quit fouled plugs then let the fouled plugfest begin. so between every change i made i was getting between 10 and 40 miles before starting again. i was running too rich.1 so i pulled the baffle and cleaned the air cleaner NOPE. 2changed coil pack/plug wires NOPE. 3. Cleaned the throttle body NOPE. 4. Engine light finally came on. took it to the shop had a bunch of ( idle air control circuit out of range) codes upon mechanics recomendation i replaced the Low air cut off valve breather solenoid and the TMAP Sensor NOPE!! 5. then found a thread about re setting the TPS ( throttle position sensor). a 10 second deal. Afterwards i heard some kind of sound that i have never heard before? This appears to have fixed it. i have well over 150 miles on it and seams to be running perfect as before. Sure hope this helps someone due to my struggles. I can post the directions for this if anyone is interested
RICZ, rainman123 and swiftdescent like this.
2010 Vegas Low
Beckley W.V.
robert a is offline
post #2 of 5 (permalink) Old 09-13-2017, 07:00 PM
Absolutely, please post the instructions. I know that I would be interested. This would be applicable to all Victory bikes and not just the steel frame ones, correct?
G'day,
Vinish
rainman123 likes this.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #3 of 5 (permalink) Old 09-13-2017, 07:44 PM Thread Starter
all i know is that this worked on my 100 cu "
1. start with key and kill switch off.
2. key to on ( let prime) kill switch on
3. slowly roll throttle from 0% to 100%.
4. Hold throttle wide open for 5 sec.
5. let throttle snap back to 0% as fast as possible
6. turn kill switch off then key off
thats it good luck
Motorbikerx, 541RF and yago20 like this.
2010 Vegas Low
Beckley W.V.
robert a is offline
post #4 of 5 (permalink) Old 12-03-2017, 03:14 AM
Kla
Kla's Avatar
Send a message via AIM to Kla Send a message via MSN to Kla Send a message via Yahoo to Kla
This does work for all Vics. It worked on my 99 V92C and it worked on my 07 Jackpot
2007 Jackpot - Victory Swept pipes, Thunder Monster Baffles, K&N Filter, Vented Airbox, PC Ill
1999 V92C Classic - Stage One Slip-ons, Stage One ECM Chip, K&N Filter
Lawrence, Pennsylvania
Kla is offline
post #5 of 5 (permalink) Old 12-05-2017, 10:08 AM
id-man's Avatar
Man the things you learn when you come to a forum!!!
Cape Cod, MA
2010 Cross Country "Scrolly"
www.VicWrapz.com
id-man is offline
