04 Vegas Arlen Ness - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 2 Post By NREED5480
  • 1 Post By NREED5480
post #1 of 10 (permalink) Old 01-27-2019, 09:04 PM Thread Starter
NREED5480's Avatar
Default 04 Vegas Arlen Ness
I am swapping out the ness bars for some 14 inch FMB apes bought a set of stock risers and the stud is to big to go through the existing bushings in the triple tree. So my question is their a bushing kit I need to buy or modify the original?
NREED5480 is offline
post #2 of 10 (permalink) Old 01-27-2019, 10:14 PM
Can you drill out the new bushings so they fit the studs?
Without actually seeing them it's hard to say if that's a good idea or not.
post #3 of 10 (permalink) Old 01-28-2019, 07:14 AM Thread Starter
NREED5480's Avatar
Bbob I can take pictures tonight to show you what I am talking about. Thank you for the reply
post #4 of 10 (permalink) Old 01-28-2019, 10:17 AM
BP6666VR's Avatar
I bought cheap-ass HD risers that fitted my HD handlebars perfectly .... On my Jack-hammer , ha ha ha
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 10 (permalink) Old 01-29-2019, 07:50 AM Thread Starter
NREED5480's Avatar
Here are some pictures of what is going on. Any help would be great
post #6 of 10 (permalink) Old 01-29-2019, 09:55 AM
Shoot. I didn't realize they had that long tube on the bushings. Probably need to get risers that'll fit or bushings that will unless you think they are close and just need a little bit more to fit.
post #7 of 10 (permalink) Old 01-29-2019, 09:48 PM Thread Starter
NREED5480's Avatar
So I removed the tube and drilled out the bushing caps just slightly fits perfectly 90% of the aftermarket ones dont come with the tube so I figured it would be ok.
BBob and Motorbikerx like this.
post #8 of 10 (permalink) Old 01-30-2019, 07:19 AM
BP6666VR's Avatar
I think i used the victory rubbers & bushings on HD risers & handlebars, i fitted perfectly, guess i was just lucky .... The imperial treaded riser bolt is almost the same diameter as the metric vic riser bolt, so it fitter just fine
The HD handlebar was too narrow for me, so i took a SOLID cold rolled roundbar and machined very heavy extensions, that act like endweights
I also had to machine the grips from HD to mach the vic trottle housing
Some pictures for youIMG20170831172932.jpgIMG20171206163741.jpgIMG20180119103955.jpgIMG20171206135203.jpg
BP6666VR is offline
post #9 of 10 (permalink) Old 01-30-2019, 07:28 AM
Motorbikerx's Avatar
now them are real Apes..none of this mini-ape shit....Koolaz!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 10 (permalink) Old 01-30-2019, 11:49 AM Thread Starter
NREED5480's Avatar
Could not get down with the mini apes had to have at least 14
Motorbikerx likes this.
