Swapping OEM Headlight to LED - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 01-30-2019, 08:40 AM Thread Starter
Default Swapping OEM Headlight to LED
So I’m in the mindset of putting LEDs on my stock 2008 Vegas 8 Ball headlamp. Can’t find anywhere in black and white about whether I can just throw a new bulb in there or if I need a special something or other.
Any of y’all changed your lights to LEDs, and what did you use?
NuclearTurtle is offline
post #2 of 7 (permalink) Old 01-30-2019, 08:54 AM
I've also considered replacing mine with a LED, but went the route of adding additional lights (denali d2's). If you do replace with the LED you may need the adapter harness. Headlight Adapter Harness Victory Motorcycle Parts for Victory Custom Bikes
2009 Victory Vegas
Shotgun Exhaust
Morris, NJ
BrianT is offline
post #3 of 7 (permalink) Old 01-31-2019, 08:40 PM
I had a HID in my 07 vegas, round 7in headlight. I just put an LED in my HB, 5.75in. I had to trim the inner bucket for it to fit. Its just a plastic piece, a Dremel took care of it. Got it from Vicbaggers last week for 59.00
Sent from my SAMSUNG-SM-G930A using Tapatalk
bumpedmyhead is offline
post #4 of 7 (permalink) Old 02-09-2019, 07:34 PM
I am going to buy a Victory LED for my 2008 Vegas. The LED light is plug and play if you have 2 H11 bulbs. The 08 Vegas has an H7 low beam and H11 high beam. Is this the adapter I need to make the LED light work on my bike? I assume so but want to make sure.
Scott
2008 Victory Vegas Low (hers) - Boardwalk Blue
2013 Victory Cross Country (his) - Antifreeze Green
Lincoln, NE
swalker is offline
post #5 of 7 (permalink) Old 02-14-2019, 11:45 AM
Scott,
I don't know for sure as I never wound up replacing mine (2009 Vegas Bullet style headlight), but if you call the store they could probably give you a more definitive answer. I think there are other threads on here or the other site about upgrading to the LED. That is where I originally came upon the adapter harness info.
Brian
2009 Victory Vegas
Shotgun Exhaust
Morris, NJ
BrianT is offline
post #6 of 7 (permalink) Old 06-06-2019, 10:09 AM
Hogeyphenogey's Avatar
https://www.victoryforums.com/161-vi...ions-pics.html
This is my LED Headlamp install- just a few forums up from here!
Good luck!
A sunny day and a full tank of gas- my little slice of Heaven!
2015 Gunner
2011 Triumph Thunderbird Storm
2010 Triumph Thunderbird
2008 Triumph Sprint ST
2006 Yamaha VStar 1100 Custom
2000 Suzuki SV650
1985 Suzuki ES550EF
Chicopee Massachusetts
Hogeyphenogey is offline
post #7 of 7 (permalink) Old 06-06-2019, 01:03 PM
rgis is not mine
https://minneapolis.craigslist.org/w...876725398.html
