2009 Vegas hesitation at 40 mph - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 13 (permalink) Old 09-21-2019, 06:34 PM Thread Starter
Default 2009 Vegas hesitation at 40 mph
Hello,
I have a 2009 Vegas with 7,500 miles. My bike ran great all summer and then just last week I noticed a hesitation while riding. I notice it most when on roads that the speed limit is 40 and I'm holding it at 40 - 45 mph. I don't know how to describe it except it feels like something is holding it back. Like it's about to run out of gas. I don't have to pull over or anything, but it does make me nervous going too far from home. It seems to be fine while accelerating, When slowing down I get some popping from the exhaust. It's very hard to describe. Just a hesitation or stumble at lower speeds. Its probably there at higher speeds I just don't notice.
I've had the bike about 5 years and never had one issue with engine performance. I got the bike with really low miles and probably only ride about 1,000 a year because of the short riding season. Another factor is that I live very close to my work and sometimes ride my bike to work which is less than 2 miles. Sometimes I go right home after work without out going for a longer ride. I don't make a habit of that though.
A few years ago I noticed a similar issue and noticed one of the battery terminals was loose. I checked them now and they are tight.
I took out the plugs. In my opinion they look pretty black. Oddly enough one had white on the Electrode bridge, but not the other. The plug more toward the front of the wheel was more white. I cleaned them with a wire brush and reset the gap per the manual. One of them was off a little, but I dropped it several times after taking it out. Re-gapped and re-installed and rode about 20 miles with no difference.
I'm stumped because I don't know what could change literally over night. Maybe it is as simple as bad gas? I have about 30 miles left on this tank. I did just fill it before this all happened.
Should I change the plugs even though I only have 7,500 miles? Also, I'm not usually one for additives, but is there any additive I should consider?
Sorry for the long post, but I was just trying to give details.
Thanks in advance
alm70 is offline
post #2 of 13 (permalink) Old 09-21-2019, 07:38 PM
Sounds like a possible intake/vacuum or exhaust leak. I'd lean (no pun intended) toward intake. You could first pull the cheese wedges and see if it's anything obvious. Maybe spray a little carb cleaner around the throttle body and boots. If nothing then pull the tank and do a more thorough check. Check the air filter too.
Could also be the injectors getting plugged up. Run a quality injector cleaner through it in a tank of gas. I'm liking the Gumout All in One over the more popular Seafoam but it's your call of course.
541RF likes this.
post #3 of 13 (permalink) Old 09-21-2019, 07:56 PM Thread Starter
Thanks Bob for the quick reply. I appreciate it. I’ll try the tips you gave me tomorrow. There isn’t much riding time left up here in the northeast so I want to figure this out before I have to put it away for the long winter
BBob likes this.
alm70 is offline
post #4 of 13 (permalink) Old 09-21-2019, 10:35 PM
541RF's Avatar
BBob has very good tips, also look at the spark plugs. You are saying the same problems I had on mine after I started riding this summer. Took a chance and installed new plugs after gapping them, Bike ran great and did not pop when slowing down.
Good luck, let us know what you find.
541RF
2004 Arlen Ness Signature Series Vegas
Black-Cherry Fade
Stage one dealer kit installed
Bags, tour seat with backrest and rack
Southern, OR.
541RF is offline
post #5 of 13 (permalink) Old 09-22-2019, 01:20 AM
Good point and sometimes plug wires get tired. If they are 10 years old it's definitely time to change them.
post #6 of 13 (permalink) Old 09-22-2019, 02:24 PM Thread Starter
Thanks for the feedback.
Update: I sprayed carb cleaner around the throttle body and boots (before changing the plugs) and I didn't hear any idle change. I didn't spray a ton in there, but in my opinion I assume it was enough. I noticed it idled a bit rough with some popping from the exhaust even before I sprayed the cleaner. I don't think there was any changes while spraying.
Next, I bought 2 new plugs, gapped them and put those in. I was excited at first because it idled a heck of a lot better with out any popping. But, once I took it on a 30 mile trip I don't believe there is any difference except maybe smoother idle at stop sign and stop lights. It still seems the worst at 40-45. Over 50 is tolerable. I hope this isn't all in my head and I'm expecting too much.
I bought that gumout cleaner mentioned above. I'm waiting for the low fuel light to come on. I probably have about 20 more miles to go. I realize there are directions on the bottle, but would you put the whole bottle in? It says one bottle for up to 35 gallons. I'm assuming my tank is around 6.
Also, spark plug wires were mentioned above? Should I get some of those? I hate just try different parts and hope for the best, but they are almost 10 years old.
Thanks again
alm70 is offline
post #7 of 13 (permalink) Old 09-22-2019, 02:28 PM
Yeah; time for new plug wires too. They will develop resistance over time.
I'd use a half bottle for the next two fill-up's.
post #8 of 13 (permalink) Old 09-22-2019, 03:47 PM
half_crazy's Avatar
What you will find is that the Throttle Body Adaptor is shot or the IAV system hoses are rotten. Rubber doesn't last 10 years regardless of mileage. Just because you sprayed stuff and the idle didn't change, that doesn't mean anything.
When you talk about a symptom like 'hesitates at 40 mph' that's not good information. 40 mph in what gear? At what throttle position? Does it do it under the same conditions in other gears?
Anyway, your symptoms indicate an extremely lean condition... that would be explained by an intake-side air leak. Changing the plugs is not going to correct an issue that could cost you an engine. Fix the problem.
2006 Victory Kingpin
half_crazy is offline
post #9 of 13 (permalink) Old 09-22-2019, 05:55 PM
Motorbikerx's Avatar
yeah, what gear are you in?
at 40mph you wouldnt be higher than 3rd.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 13 (permalink) Old 09-22-2019, 06:18 PM
half_crazy's Avatar
Like "The bike is herky-jerky at 30 mph is 5th gear"?
