Vegas having issues starting. - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 06-13-2011, 02:55 PM Thread Starter
Default Vegas having issues starting.
I have a 05 vegas, just bought it about two months ago with 1100 miles on it now it has 2800 on the odometer. I was riding it the other day and it started to cut out on me so i pulled over and shut her off then when i went to start it up again i turned the kill switch on and the fuel pump fired up like normal then shut off but about a half second later it started up again and kept running i started it and it took a little bit of cranking the engine but finally fired up. It didnt like to sit and idle it kept burping and cutting out. Eventually it went back to normal and the engine light went off. Then about ten miles later it shut off at a light and had the same issues. Any ideas or info would be much appreciated. thank you in advance!!!!!
2005 Victory Vegas
Arlen Ness Drag Bars
Shifter Peg,Foot Pegs, and Gripsthumb up
AK-BUSH-PILOT is offline
post #2 of 5 (permalink) Old 06-13-2011, 03:10 PM Thread Starter
I forgot to mention that it is starting just fine now it seems to be random that it acts up while running or starting. I also hear clicking at the back of the fuel tank when the fuel pump runs continously.
2005 Victory Vegas
post #3 of 5 (permalink) Old 06-13-2011, 03:48 PM
The Diamond
diamondrmp's Avatar
A little time with the search feature will produce threads on this.
Saying that check all connections on the battery and insure they are tight.
diamondrmp is offline
post #4 of 5 (permalink) Old 06-15-2011, 07:54 PM
VEGASMAN's Avatar
if it cranks over just fine and wont fire then its either fuel or spark. sounds like you can hear the fuel pump running so i wouldn't start there. Double check all your connections, especially the crank sensor down by your left foot near the oil cooler line. If thats unplugged or bad connection she wont start. Could be fouled plugs too. I've experienced both those same issues. Good luck!
LIFE'S BETTER WITH A TURBO :D
'06 CUSTOM TURBOCHARGED VEGAS JACKPOT
7 degree Trees and dropped.
VEGASMAN is offline
post #5 of 5 (permalink) Old 06-15-2011, 09:25 PM
kevinx's Avatar
You have a shorting speed sensor, and it is back feeding through your auto cancel to confuse your ECM. Easy test is tro unplug it, and go for a ride. Chk Eng light will most likely be on, but all the other symptoms will go away. Symptoms are classic
kevinx is offline
