Handeling problem - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 11-09-2011, 07:17 PM Thread Starter
Default Handeling problem
Hi, Bought a 2007 Victory Vegas a couple of months ago. I must not be used to it yet because the balance seems all wrong to me. Call me crazy but it seems that the skinny front tire wants to cause the bike to steer very quickly and follow cracks and groves in the road. It also feels like the front end has no weight on the road. Is this what I can expect from the front tire ?? The air pressure is at the correct 36psi. Has anyone else had a problem adjusting to the front tire ? Thanks Jack
jackgermain is offline
post #2 of 5 (permalink) Old 11-09-2011, 08:38 PM
06vitory's Avatar
Your skinny front tire will track in grooves and cracks. that's why touring and cruisers have fatter front tires. But check your tires that they are a matched set. and the condition of the tires. If you have a raidial and a bias ply your bike will act squirly and could be dangerous. If all is good next time try a differant brand tire. There are as many opinions as stars in the sky of what tire is best. Dig into this fourm through the search window and make your own decision.
2006 Kingpin Deluxe
Stage 1 pipes
Dunlop D407 & D408 tires
06vitory is offline
post #3 of 5 (permalink) Old 11-09-2011, 11:31 PM
Bad V V's Avatar
If you are over 200 lbs front tire must be at 38 psi and the rear 40. I used to have similar complaints and since I have my pressure at the correct number bike has been a huge joy to ride.
Also how many miles do you have on the bike? If you are at 15k or getting close to it, it's time for fork service.
2003 Victory vegas
Bad V V is offline
post #4 of 5 (permalink) Old 11-10-2011, 08:42 PM Thread Starter
Hi, Thanks for the tips. I only weigh about 150lb. My bike has 14, 500 miles on it. What do they do with Fork Service ? By the way, the front tire is a lot newer than the rear tire. Both are Dunlaps.
post #5 of 5 (permalink) Old 11-11-2011, 09:44 AM
Bad V V's Avatar
It's just an oil change. Some of the members done it in their garage but I took mine to the shop. They were done in one hour. I forgot the exact amount but I think it was around $140 for the whole thing. I ended up going with little heavier fork oil and that also did improve the bike's handling big time.
2003 Victory vegas
Bad V V is offline
