turn signal indicator? - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 05-20-2009, 09:35 PM Thread Starter
New Member
Default turn signal indicator?
anyone know why the turn signal indicator bulb would not illuminate yet the blinkers still work fine?...first thing i did was change the bulb but still nothing. 2005 vegas any help would be appreciated
fixius03 is offline
post #2 of 3 (permalink) Old 05-22-2009, 07:54 PM
dogzilla07's Avatar
Smile
Try checking the connections in the headlight assembly. I recently installed the digital speedo and had the same problem you have. After checking everything again I found a loose connection. Hope this helps!
dogzilla07 is offline
post #3 of 3 (permalink) Old 05-26-2009, 07:37 PM Thread Starter
New Member
i took it all apart no loose connections. i pulled the bulb and put a multimeter on it and its got power so the socket has to be bad or bad connection. i used a bulb from another indicator which i knew worked so it cant be the bulb.
fixius03 is offline
