What are these plugs? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 12-25-2011, 09:10 AM Thread Starter
vindex1963's Avatar
Default What are these plugs?
Are these accessory plugs?
They have no covers and are packed with grease.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #2 of 6 (permalink) Old 12-25-2011, 10:42 AM Thread Starter
vindex1963's Avatar
I found out. Accessory plugs.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #3 of 6 (permalink) Old 12-25-2011, 09:20 PM
bhaxton's Avatar
Vin, your makin me feel better. I thought i was the only one that didn't clean where the sun don't shine.
2012 High Ball, changing all the time. "OOPS I bought another Wide Glide"
"The difference between stupidity and genius is that genius has its limits." Albert Einstein
bhaxton is offline
post #4 of 6 (permalink) Old 12-25-2011, 09:25 PM Thread Starter
vindex1963's Avatar
I bought it used and the original owner let it sit for 7 years. The entire bike was filthy. I've since cleaned it up. It doesn't look like that now but I'm thinking it will again.
I'm finding loose connections under there.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #5 of 6 (permalink) Old 12-25-2011, 09:39 PM
bhaxton's Avatar
Loose connections ain't good. I smiled when I saw the pics.
I mounted a tractor set on my high ball and a buddy was giving me a hard time about how dirty it was under the new seat. Needless to say it's cleaner now, but wasn't that dirty at the time. No bad on you, I just got a chuckle out of it. (My head does strange things.)
bhaxton is offline
post #6 of 6 (permalink) Old 12-25-2011, 09:54 PM Thread Starter
vindex1963's Avatar
aaaa a little dirt just means you ride it.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
