1 - 3 of 3 Posts
ok those of you with cross bikes with pcv and basic mods, what kinda fuel settings are you running in your 0 column? i am at -8 in front cyl and -10 in rear and still seems rich. i have tried setting it with it idling and watching the running af gauge on my laptop but currently showing 16ish at idle while puffing black smoke when i burp it. i am setting the 750-1000rpm blocks in the 0 column for idle, it appears to be the 1000 block that is effecting it.
What are you getting for mileage on your bike?
So your saying low end is rich but the rest is OK.
I though you had it dyno not to long ago
i havent been on any longer runs at all, been riding to work the last couple weeks to a new job thats 12 miles from home. i have the auto tune and my af set at cruising is about 14.5 and 14.3 so cruising is good, but the 0 column is said to not use the auto tune but set with the fuel settings. and yes i had it on a dyno to see where it was, and with the vfcIII it was way to rich at the lowest settings so i got the pcv with auto tune now. ideally i want cams then a dyno but for now i need to go as is.
1 - 3 of 3 Posts
