1 - 2 of 2 Posts
I recently had my V92C painted. After carefully putting it back together, and before putting gas in the empty tank, i decided to turn the key on and test brake lights, turn signals, ect. Battery sat inside, unconnected all winter. Unpon turning the key, the headlight comes on and the dash shows oil light and flashes the low fuel light. Also, the dreaded 5 33E error comes on. When the fuel light flashes, theres click noise (guessing fuel pump relay) and the cycle starts over. The brake light works, however no turn signals or 4-ways. Horn is very weak and barely sounds. And there is absolutely no attempt to roll over. Was thinking either A. Fuel pump is throwing the code due to no fuel or B. battery is low from sitting all winter. Any help would be greatly appreciated. Thank you.
1 - 2 of 2 Posts
