1 - 10 of 10 Posts
Battery fully charged,lights come on bright,when starter button is pushed: solenoid clicks,lights stay bright,starter does not engage.Jumping pos terminals on solenoid does not work.I do get power to starter.Sounds like a bad starter,but it's hard to believe because bike has low miles.
sounds pretty cliche but i'd try hitting the ends of the starter perhaps the spring mechanism in the starter is stuck and needs to be "encouraged" to release
The Diamond
Not trying to badger you but I've seen and fixed this on customers bikes SO many times.
Did you check all of your grounds?
If that doesn't work Ebay has a LOT of aftermarket starters that are just as good as OEM.
A thought just occurred to me. Are you running a stock engine? If you have bumped up the cubes ot gone to higher compression pistons then you probably do need a new starter.
Discussion Starter · #10 ·
Well sometimes just is what it seems. I opened the starter ( after removing the complete exhaust system,what a hassle). The bottom end was totally chewed up.I guess I'm going to be spending the weekend on EBAY looking for a starter.
Thanks Again
1 - 10 of 10 Posts
