1 - 1 of 1 Posts
Hello ,My kingpin starter went out and when I removed it burnt oil drained from the ecu mounting bolts.I figure the starter shaft seal went bad and allowed oil in which burned the starter motor.Has anyone had the same problem?Also why can you only get aftermarket starters for up to 2005 models?I the dealer wants $375 for a new one.Thanks
1 - 1 of 1 Posts
