1 - 5 of 5 Posts
I have a 2008 Jackpot.. Need to know how to remove the triple tree enough to slid the MBW Wrap Around LED on the fork..
Any videos or advise.. Please..
You don't need to remove the triple tree. Just loosen the 4 pinch bolts on each side and follow the directions that came with the signals. It was pretty easy, I just did mine tonight. Be sure to check your bikes signal wiring to see if it's reversed.
Just follow the instructions that came with them. I used an engine hoist with straps around the risers to lift the front end up. Do both sides at the same time, I found the shocks slid down about a 1/4 inch at a time really easily, otherwise you are fighting the compression of the springs.
Super easy.
I got one at Pep Boya a few years ago for like $30 with a $30 rebate. Or if you have a Harbor Freight near you they have them pretty cheap. Also Sears has them for around $100.
1 - 5 of 5 Posts
