1 - 3 of 3 Posts
The center head light is not working on my 08 vision. I don't ride much at night so i had not turned it on for a couple years and now it's not working. From what I understand it is an HID light from the factory. I'm not sure if it would be the bulb or possibly another issue. I tried removing the bulb so I could unplug the connector and check for power but can't figure out what holds the bulb in. i have the air filter removed and the rubber boot pulled back. I can feel what I believe is the ballast on the bulb but can't tell what holds the bulb in place. I have found all kinds of info and videos on removing the other 2 bulbs but can not find anything on the center bulb. I would remove the entire headlight assembly if needed but can't find any removal info for that either. Any help or guidance would be appreciated. thanks in advance
Just saw this. The light type should be in your owner manual. That being said it is this -
Vision Aux Driving Light – Center light Polaris part number is 4011379 and the lamp is an HS-1 12v 35/35w, PX 43t fitting. As I remember it any "HS-1" bulb with PX 43t fitting will work. ;-) LMYR
1 - 3 of 3 Posts
