1 - 4 of 4 Posts
590 Zumo, where can I hook this bad boy up that is switched power? I see 2 connectors under the seat, the manual says its for hid lights.
Is there an "accessory" connection somewhere on this bike?
Thanks for the link, I did see that thread, but I was hoping to tap into the accessory fuse somewhere, I want to keep it clean and as "factory" as possible. Any other ideas?
Followup: According to the wiring diagram, there is a yellow/red and black circuit running the length of the bike that is supposed to be used for accessories.
It was under the seat buried in the nest next to the ecm. I tapped my zumo into there after routing that long ass cable along the main harness. Works perfectly!
I did some more tracing and found 2 other connections to that same circuit: one under the tank taped to the harness and one in the headlight bucket. Just in case anyone else is looking for this.
1 - 4 of 4 Posts
