1 - 5 of 5 Posts
Well this morning on my ride into work, my fuel light came on. This struck me as odd, as I had just refueled 35 miles prior. I topped off the gas tank, and it only took a gallon. When pulling into the gas station, my turn signals failed to operate.
Mods are as follows: rear turn signal flush mount led, Lloyd's fuel controller, ATS, intake, and some conquest customs octane pipes.
Any help would be greatly appreciated!
Pauly C.
Are you running LED's just in the rear? Do you have a load equalizer in line and are any of the mods you listed new as in recently installed?
Yes, LEDs only in the rear, stock up front. No, I do not have a load equalizer. I installed the mods in January, about 4000 miles ago
if you have a fast flashing turn signal then yes you need a load equalizer.
Pull seat and with 10mm wrench check to see if battery bolts are tight
I have one fast blinking, and one regular blinking. I'll look into getting a load equalizer. Are they all the same, or is one model better than another. Anyone have a suggestion which one to get?
I'll check the battery connection today.
I was thinking there might be a ground somewhere.
1 - 5 of 5 Posts
