1 - 18 of 18 Posts
Today I installed a witchdoctor 2 inch lowering link and shortened kickstand. First a big thanks to witchdoctor for the how-to videos. They really helped (especially the kickstand ). The lower bolts on the link and the shock were a bear. Watching Jon on the video, it looked easy. Thank God for breaker bars. The only real snag was the bolt that holds the pivot pin in place. The threads were boogered up when I removed it. Once I ran a die over the bolt, all was good and it went back together well. No test ride tonight. I was hot and the pool looked too inviting.
Looks great Ed , I did the 1.5 drop a couple weeks ago ... A great mod !cheers
I meant to also say , your belt will probably be way too tight now and will need adjustment , and so will your headlight ... WD doesn't mention this ....
Yeah, I was wondering about the belt and didn't even think about the headlight. I'll check it out tomorrow. Thanks for the reminder.
Loosen your axle nut , back both adjuster nuts off exactly 1 full turn each , tap wheel forward , tighten axle nut ... Good to go .
he may need to go more with a 2" drop, but that will be better then not adjusting it.
Quick question for you guys that did the lowering link. I have a buddy that is 5'7" with this link. Do you think he can be flat footed on the floor or a least close?
Quick question for you guys that did the lowering link. I have a buddy that is 5'7" with this link. Do you think he can be flat footed on the floor or a least close?[/QUO
not knowing what lowering link he has he should come rear close to being flat footed.
Guys put 40 psi in your shock so you don't bottom out. Ride for a month all is good take 10 psi out and see what you think.
Remember you can't add air at 60 mph
Speaking from experience!! I am a bit vertically deficient at 5' 5". I have the 1&1/2 in drop link installed, I can't quite get flat footed but It's close enough that I'm very comfy with my foot placement when stopped. (Backing up is admittedly a bit of a PIA) I leave 10 psi in the shock w/the trunk on. I'll drop it to zero if I pull the trunk. This seems to work well when riding by myself. When my prettier half jumps on, I bump the shock up to 62 psi. (She only rides with the trunk on)
It may take a little experimentation to figure out exactly where you're comfy at a stop, but it's one more great excuse to go for a ride!
On a side note, I weigh in at 180, and let's say my pretty half is much less!!
go slow out of driveways to prevent bottoming out exhaust
I will probably install the WD link on his bike. Thanks for the quick feedback. I will pass it on to him so he can feel more comfortable.thumb up
i just made a link for a buddy of mine, hes 5'6-5'7 and with 20psi in his shock and a 1.5" drop he is flat footed. i have a core link, i can make your buddy one if interested, $70 shipped plus $40 core that i return when i get his stock link back.
I will let you know, he is currently in Paris right now. Have to wait till he gets back.
I have the Miller link , its better then new .
Mr. Miller,
I'll take you up on a 1.5" lowering link if you have another core to work with. I'll be happy to send you my stocker after the install.
Thanks, Jim
So how is the best way to check the belt without the correct tool? I put an adjustable link in and lowered it about 1/2". How can I test to see if it is adjusted correct?
Mr. Miller,
Thanks, Jim
shoot me a pm, we will get you taken care of!
the tool is about $15, buy one and get it right.
1 - 18 of 18 Posts
