1 - 3 of 3 Posts
Hi All,
New to the forum, and learning tons...
I posted this up in the new members forum, but am hoping to get additional direction here.
Looking at 2 different bikes - both 2000's. one an SC, and the other quoted as a Deluxe. The SC is in better shape, and looks like its been maintained better, but I like the Deluxe a little better on the basis of fit and trim...
My concerns: The tranny upgrade... That issue doesn't come up in the VIN search, and I haven't been able to determine how to tell if it's been done. Both sellers aren't original owners, and can't say for sure. How can you tell without pulling the engine apart?
Both of the dealers I've talked to about scheduling an inspection have tried to steer me away due to lack of parts availability.
I'll post the VIN history here in case anyone can give me some insight based on that...
Thanks in advance for any help you can give me.
Discussion Starter #2
V92C,TWO-TONE,STEEL-GREY,BLK
Search or Select Another Vehicle
YOUR INFOVEHICLE INFOMANUALS & GUIDESSAFETY & SERVICE BULLETINS
Bulletin Status Bulletin Information
Bulletin Completed V-01-01 - REAR SHOCK REPLACEMENT
Bulletin Completed V-02-05 - FUEL PUMP REPLACEMENT
Bulletin Completed V-03-05 - UNEXPECTED SIDESTAND DEPLOYMNT
Applied on Bulletin No. V-06-06A V-06-06 - DRIVE SPROCKET INSPECTION ONLY
Bulletin Completed V-06-06A - DRIVE SPROCKET INSP & REPLACE
Review bulletin to see if it applies V-00-02 - DRIVE SPROCKET RTN NUT TORQUE.
Bulletin needs to be applied V-06-07 - REAR SPROCKET INSPECTION ONLY
V92SC,SPORTS-CRUISER,MONOTONE,STEEL-GREY
Bulletin Completed V-01-04 - BRAKE ROTOR FASTENER REPLACMNT
Bulletin needs to be applied V-06-06 - DRIVE SPROCKET INSPECTION ONLY
Bulletin needs to be applied V-06-06A - DRIVE SPROCKET INSP & REPLACE
Review bulletin to see if it applies V-99-14 - INCORRECT OEM FRONT TIRE
1 - 3 of 3 Posts
