1 - 3 of 3 Posts
I'm having major lighting problems with my 2001 Victory V92C. The headlight won't work and does not get any voltage to the plug. The rear running light works but the brake light does not. The turn signals don't work except when they're on the hazard setting then they work fine. I checked the headlight relay and switched in a new one and it doesn't seem to be the problem. Any ideas?
I don't have much experience with bikes but have you checked all the wires? There might be a short in one or two of them, maybe the covering rubbed off or something. I think you should probably check each wire.
Just figured it out. There was some extra wiring for auxiliary lights that had gotten crossed which was blowing one of the main fuses. All is fixed and well with the bike cheers
1 - 3 of 3 Posts
